#21 |
Liked 11 Times in 4 Posts
Well I don't think I've ever seen a stocker oil the track. However at the Dutch on Friday afternoon a blue 69 camaro did a moonshot wheelstand and upon landing pitched out what appeared to be the trans blanket. That was something new in my world.
![]() Mike Z |
#22 |
Liked 6 Times in 2 Posts
We had a Jr. Dragster oil the track this year. Last weekend it was a Stick car that split the trans case. Numerous rear end explosions, auto trans blowups, oil line leaks and rad hose failures. I'd think engine failures are becoming a lot less with improved and accepted parts.
I'm all for safety but how many Diapers should be on a race car anyway. If you want to run one then fine, but I don't, probably can't fit one and don't think making them mandatory is a good move.
Dale Posnick |
#23 | |
Does not look like 1969 Camaro to me, but maybe more than one car pitched its safety gear off mid track. First time I'd ever seen this happen. |
#24 |
Liked 684 Times in 289 Posts
#25 | |
![]() Mike Z |
#26 |
Liked 602 Times in 165 Posts
We had a D1 race where 3 Stockers oiled the track during the first Qualifying shot. I myself have oiled it twice. First when I bought the car I was the first car down the track at No Problem and spit a rod out at bat mid track broke the trans driveshaft and pinion yoke too. Shut the track down for almost 2 hours. So yes it does happen.
#27 |
Liked 10,968 Times in 2,261 Posts
After looking at the B-E body engine, steering, and headers on my stocker, it would be a lot of work and expense. The drag link runs real close to the sump and the bottom of pan, this could be a potential crash if the Kevlar blanket jams the steering. A motor plate would not help the steering situation. A tray might work until a big wheel stand. When that happens on my car it bends the oil pan against the pickup, and bends the transmission pan. The oil pan I have to fix before I make the next run. If new ss headers are needed to complete the ORD I will be done.
All of a sudden cutting bait doesn't look so bad. Last edited by Larry Hill; 10-07-2019 at 07:11 AM. |
#28 |
Liked 93 Times in 29 Posts
Stock eliminator- entry level. Mandatory belts every 2 years, mandatory approved collector tethers, now mandatory diapers? Sad to see the so-called evolution of this class.
#29 |
Liked 695 Times in 206 Posts
On a Hemi car with the drag link going through the oil pan (some Chevy ll’s also), I do not know how you could fit a diaper effectively. If NHRA allowed an aftermarket K frame, it might be possible.
#30 | |
Liked 292 Times in 147 Posts
I wasn't real fond of putting it on, but when the rules require it (I ran the car in S/ST a few times...ex-SS car), you find a way to make it work if you want to race. While the Jeg's diaper doesn't provide the best fit, I can only imagine how much better the job would have been had I used something that was designed for the car. |
