Old 10-07-2019, 10:48 AM   #31
B Parker
Liked 2,343 Times in 465 Posts
Default Re: Engine diapers on S/SS?
After looking at the B-E body engine, steering, and headers on my stocker, it would be a lot of work and expense. The drag link runs real close to the sump and the bottom of pan, this could be a potential crash if the Kevlar blanket jams the steering. A motor plate would not help the steering situation. A tray might work until a big wheel stand. When that happens on my car it bends the oil pan against the pickup, and bends the transmission pan. The oil pan I have to fix before I make the next run. If new ss headers are needed to complete the ORD I will be done.
All of a sudden cutting bait doesn't look so bad.
Larry I love your pink car. And I'm jealous of all the races you get to go to. But if you were to cut bait could Patsy still go and report. Class racing would not be the same without her. Barry
Old 10-07-2019, 11:12 AM   #32
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Talking Re: Engine diapers on S/SS?
Originally Posted by rboyle View Post
We had a D1 race where 3 Stockers oiled the track during the first Qualifying shot. I myself have oiled it twice. First when I bought the car I was the first car down the track at No Problem and spit a rod out at bat mid track broke the trans driveshaft and pinion yoke too. Shut the track down for almost 2 hours. So yes it does happen.
Excessive RPM's will do it every time. Now you have solid lifters to go along with the killer valve springs and excessive duration cams and roller rockers, etc. ! What else would you expect unless you spend several thousand more dollars to build modified and S/S wanna be engines. You get what you wanted !
Old 10-08-2019, 01:42 PM   #33
Originally Posted by Steve Stasko View Post
I wasn't real fond of putting it on, but when the rules require it (I ran the car in S/ST a few times...ex-SS car), you find a way to make it work if you want to race.
Don't have a dog in this hunt, but never stopped me before.
Steve, I don't have a rule book, but are you saying that S/ST, the entry level class, where the index is only 10.90, requires a diaper?
Old 10-08-2019, 02:45 PM   #34
jmcarter
jmcarter's Avatar
Liked 3,232 Times in 983 Posts
Mark, yes an oil retention device is required in Super Street. Believe it would already be in place but the last time they floated it the heard how much of an impact it would be. Strangely enough bracket cars don’t require, likely because they don’t put the Fuel Circus at risk of losing any track time. I’ve already submitted my impact statement to the SRAC. Have a Stefs pan with hole for the drag link to travel through, custom made headers by REF that come very close to pan in several places. Even if one could be custom made it would come very close to the belt drive. As stated earlier if they hand down the rule as mandatory then current car will no longer run in Super Stock
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 10-08-2019, 11:20 PM   #35
Steve Stasko
Liked 290 Times in 147 Posts
Correct...that and the flywheel shield were the only two things I had to add to the car for S/ST. I know a lot of tracks were requiring a diaper on Sub-10 second cars as well for their weekly bracket programs. I don't know if I needed the flywheel shield though as the car runs less than 135 mph?
I don't think the diaper should be mandatory...but it's definitely cheap insurance.
For what it's worth...The rulebook does state that a minimal number of slots or holes to "clear frame, steering, or lines" is permitted.
Old 10-09-2019, 01:05 AM   #36
Well guys, There's a way to address the S/ST issue.
No electronic throttle stops , and a 125 max speed (breakout).
In other words, bring it back to entry level.
But why in the hell would they?
Look what they've allowed to happen to Stock.
Old 10-09-2019, 10:00 AM   #37
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Why would you think S/ST is supposed to be entry level?
I only go 12x MPH on 9" radial tires, but I like the diversity of the class just the way it is.
I don't care if Stock and SS are allowed to run without a diaper, but the drag link through the oil pan and close-fitting headers are not issues that would prevent one from being used. As I mentioned in my first post, my diaper has holes for the stock motor mounts and has Kevlar side panels where the headers touch.
S/ST 51
S/C 53
Old 10-09-2019, 10:47 AM   #38
jmcarter
jmcarter's Avatar
Tony, is your diaper a custom made piece that retains the SFI certification? I know from long past experience trying to fit a TCI aluminum shield on a 727 in a Duster that some creativity is sometimes required. Asking for a friend....
And I agree that Super Street is far from entry and is one of the most entertaining and diverse (well, except for Comp of course) classes. Witness Nick Vogelsang‘s recent slaying of all comers in D3. 50 mph finish line speed differential is remarkable. Recall long ago when NHRA enacted the “Scotty Rule” and how the class has changed since those days. Fletcher winning his 100th in their Super Street Nova speaks volumes.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 10-09-2019, 11:44 AM   #39
Why? Because NHRA promoted it that way originally . Maybe you weren't around back then?
Divisionals only..No nationals
No national points/ champs
No running S/ST and another category at the same event.
In other words, a simple class for local bracket racers who want to try NHRA racing, locally.
Another case where it looks like the inmates are running the asylum.
Only question is..Who are the inmates here?
Old 10-09-2019, 11:55 AM   #40
Lenny5160
Lenny5160's Avatar
Sportsman racers are not required to have SFI-certified diapers; they must only be NHRA-accepted. Never has a tech person really inspected the diaper on either of my cars to ensure that it was a particular "accepted" brand or type.
With that said, I do believe that the custom DRE diaper on my Nova is SFI-certified. The universal-style diaper on my dragster is not SFI-certified.
S/ST 51
S/C 53
