Old 10-07-2019, 02:42 PM   #1
steve hanby
Default For Sale: 1994 Camaro Z28 Built by Steve Hanby
350 LT-1 Real Superstock engine-Panella-Hettler-Bowdish
Engine specs: 115 runs on this engine, dart block, bushed lifter bores, Gary Hettler heads,Panella short block and machining, engine assembled by Alan Bowdish (A-1 Performance Trans and Converters), Bill Miller pistons, total seal rings, Manley rods, Hettler camshaft 4-7 swap,Edelbrock intake with Hanby modified elbow, Moroso aluminum kick out pan, Pac springs Comp lifters, MSD Ignition digital 7530, coil, crank trigger, Holley Commander 950 ECU, Meziere water pump, Pan evacuation system, Hedman headers 1/3/4-1/7/8 step, Performance welding stainless steel merge collectors, Scott MCclay transmission 2.74 low gear auto 1-2 shift, A-1 6000 8" converter, JW bell housing recerted 5-18, ATI new flywheel 12-19 cert.,Summit trans blanket 7-18, PST aluminium drive shaft,Strange 12-bolt rear 4.88 gear LPW cover and braced by Hanby, Mark williams brakes all around new pads and calipers rebuilt 4-18, Weld wheels all around with a spare set of fronts and rears, One new set of MT 30x9x15R
Radials. The engine has never been over 7500rpm and should make
power to 8500rpm. The auto 1-2 shift takes place @7000 2-3 @7500 and back doors @7500. This car has never been tested to its full potential! Best bracket pass, 10.31 127.90. Car has always been run 100# over the minimum weight of 3515# ie, 3615#.
Available turn key or roller with trans and converter.
$40,000 Pictures on request.
Steve Hanby 503-931-6224
steve hanby is offline   Reply With Quote
Search this Thread:
Advanced Search
