Liked 6 Times in 3 Posts
Next year bracket car project .. planning to install them on a 496 CI... What valve be useful. 2.18/1.88. Or can I fit a 2.25/188... No limited to class.... compression ???....do I used a open chamber or closed chamber piston... Thanks all for help
Can get any help from 1 person?????
Liked 373 Times in 129 Posts
You will use a open chamber piston. The head will have to be clearanced back behind the exhaust valve to clear most pistons.
Example: Last edited by HP HUNTER; 10-11-2019 at 08:06 PM. |
Liked 482 Times in 159 Posts
Years ago I ran a 468ci with 049 heads w/ 2.19" & 1.88" valves,.680 lift solid roller cam, Speed Pro 7040PA pistons, Fel Pro .039 head gaskets and 850 cfm Holley, ran strong. Camaro that was approx 3000 lbs with me on board, 3500 rpm converter, solidly mid 10's. IIRC intake was Strip Dominator oval port.
