Old 10-19-2019, 11:40 PM   #1
Tex013
Liked 43 Times in 25 Posts
Default Drag radial life/ max passes ?
Hi ,
I know a lot here run either Hoosier or Goodyear radial slicks
What lap life are you achieving ? Car is 3780lbs Plymouth Satellite 680hp big block , 4.1 gear transbrake , 10" rim
I currently run MT pro bracket radial 29.5x10.5 but there is none newer than 2016 available here in Oz and no idea if newer coming .
I would like to see 100-125 passes minimum . This is bracket racing car runs high 10.20s , 1.42-1.44 sixty .
If there was a true 29" radial i would be happy , quickest pass ever was on a 28"PBR , and think the 30" may be just a tad too tall . I have run Hoosier 275s before but only got 70-85 passes . Never run Goodyear .
TIA
Tex
Tex013 is offline   Reply With Quote
Old 10-20-2019, 09:55 AM   #2
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Default Re: Drag radial life/ max passes ?
I run the Hoosier 30 x 9 C07 radial on a car that performs almost exactly the same as yours, and I get 150-200 runs from them. I also have a 10" rim and run 17 psi.
I do a very short burnout with no line lock and the tires perform great through their entire life.
S/ST 51
S/C 53
Old 10-20-2019, 11:10 AM   #3
countrypuppy4865
countrypuppy4865's Avatar
Liked 228 Times in 70 Posts
150-200 runs with Goodyear 30x9. Pretty much any new radial shouldn’t need a whole lot of burnout.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 10-20-2019, 04:41 PM   #4
Tex013
Thanks guys .
If I can get that many passes I will be good for a season . They are over $400 each here so got to help the budget .
Looks like I will go the Hoosier , I know the distributor has just got a new delivery so they cant be too old .
Tex
Old 10-20-2019, 06:47 PM   #5
Liked 10,769 Times in 2,238 Posts
Goodyears give me 175/200 runs and still have check holes. Best 60' low 1.28's 3250# car 10'' wheel, NHRA A/SA six pack. 92 5/8 roll out also available in 94'' roll out
Old 10-20-2019, 07:25 PM   #6
Tex013
thanks Larry .
I believe they only have the 1 Goodyear available here , will double check
Tex
Old 10-23-2019, 01:33 AM   #7
Tex013
ok
thanks everyone .
Bought the Hoosier 30x10.5 R15 , 92 rollout . Only tyre I could get that was not sitting too long , GY was 94 . Shorter tyre should help , PBR was 94.5 . Will start @ 19 1/4 psi and shock settings as used before .
If I can sit low 1.40s I will be happy
Darn the $ exchange busted the price out . Better get a season of racing .
Tex
Old 10-23-2019, 05:44 AM   #8
tuffxf
Liked 11 Times in 5 Posts
G,day Tex,
What p/no tyre was that mate if you don't mind?
Cheers
Paul
tuffxf is offline   Reply With Quote
Old 10-23-2019, 09:38 AM   #9
Lenny5160
Lenny5160's Avatar
I'd guess it was the 18215.
The 18214 also fits the description, but if looking for longest possible life, I wouldn't use the 'lightweight' tire.
S/ST 51
S/C 53
Old 10-23-2019, 04:36 PM   #10
Tex013
Yes it was the 18215 tyre
Paul , I bought it from Hoosier Aust here in Sydney
Tex
