#11 |
Liked 226 Times in 76 Posts
REM finishing your gears does help reduce friction between the gear mesh. Getting your gears down 4 Ra surface finish still enables the teeth to still have enough roughness to hold an oil film. Based on what I could learn from the Microblue website, the surface coat is to encourage cover and retention properties of the oil but won't change the surface hardness. My first guess is that you would then be able to run a lighter weight oil in the diff, and thus be able to reduce the windage and churning losses associated with gears going through and slinging oil. Like any of these kinds of changes, the percentage gain is minimal, but I can not see it making the car slower. As another data point, Nascar ring and pinions are DLC coated these days and that combined with improved tooth geometry I am told yields 1-2 mph in an A to B comparison test on a Super Speedway depending on the ratio used. There are 42 different ratios for nascars...
Andy Friar |
#12 |
Liked 805 Times in 245 Posts
Don't want to name names as I don't want to get them in trouble but I was told by one of the gear suppliers that it is a waste of time, that the gear basically polish themselves over a period of time. In that instance, I was ordering gears and was requesting the added surface treatment, why would he turn down the extra money if he thought it was worth it?
Jim Caughlin SS6019 |
#13 |
Liked 584 Times in 94 Posts
Years ago, when "Pro Gear" sets were becoming no longer available for certain applications, I started researching metal treatments to prolong gear life in my mopar. My search led me to Cryo and Rem finishing, or a combo of both. It didn't take long to realize, like a lot of stuff, that who was doing it and how it was being done mattered. I bought my own equipment so that I could control the processes in my shop. I'm not sure I saw any real E.T. improvement, but …( I did like thinking that I did )... . What I did see, and a testament to the treatment was triple the gear life in my 8 3/4 mopar gears. I went from breaking ring and pinions at around 40 runs, to taking them out, (for no real reason}, selling them used at 120. I'd say this is also why someone who sells gears, or doesn't do the process in house might not recommend it... just sayin ! Also, I think you'd look pretty hard to find a Pro Stock team, or a Nascar team that doesn't do every one of their rears.( check with Tommy Lee ) - Good enough for me.
#14 | |
Liked 165 Times in 51 Posts
Glen DeMenge 1969 Camaro Stock Eliminator |
#15 |
Liked 88 Times in 28 Posts
No REM here, just cryo, as stated by others, big increase in longevity.
#16 |
We always Cryo'd before Rem..... Also, it's not recommended to Cryo used parts.
#17 |
Liked 225 Times in 136 Posts
Too much Cryo can make parts brittle!
#18 |
That's a pretty broad statement Ralph …. Much better stated as cryo done incorrectly can make your part brittle. You could program your machine to slowly lower the part to Cryo temps ( -300 degrees ) say over 48hrs. Once the part has reached the "soak" cycle say -310 degrees, It can stay there as long as you wanna spend money on Nitrogen to keep it there. Which would be a waste of time and money. The key is to not "shock" the part by cooling it too quickly, and to not warm it back to room temp too quickly. The program we used for a ring and pinion was 8 hour descend, 8 hour soak, 8 hours back to ambient, follow by a 2 hour "normalizing" where the parts are warmed to +200 degrees for an hour, then allowed to cool to room temp all by them self. Good Cryo machines can do all these steps without ever opening the machine once a run begins. There will be little, if any, effect on the parts heat treatment. Additionally, the Timed Steps of the run are based on the total weight of the parts in the machine... If you really want to "see" cyro in action, treat your Drill Bits, Mills, and Lathe Tooling... Now you know the rest of the story. ... Hopefully, you're now armed with enough info to ask the correct questions at your Cryo shop of choice. If they're skipping any of these steps, beware of any BS that will follow in their excuses and explanations of how they do it !
#19 |
Liked 693 Times in 205 Posts
Good information. I have always done the valves on my Hemi and also the last set of Pro Gears. Good so far 👍
#20 |
Liked 706 Times in 283 Posts
Valve springs on BBC. Lasted 3 times longer
