Old 11-05-2019, 02:54 PM   #1
427FE
427FE's Avatar
Liked 348 Times in 79 Posts
Default Zero decking ?
Are both practices of zero decking acceptable?
Cutting deck and measuring deck height and adjust pin height
or
Pre-assemble and measure using dial indicator/bridge, then decking
Thanks
Pat Clemente
#1427 B/S
427FE is offline   Reply With Quote
Old 11-05-2019, 06:51 PM   #2
GTX JOHN
Default Re: Zero decking ?
Easier for me to preassemble.
John Irving
741 Stock
741 Super Stock
Old 11-06-2019, 03:06 AM   #3
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Pre-assemble with the pistons, rods and bearings you will be running. I just did this with a Dart SHP sbf. I used a dial gauge and double checked it with a bar bolted across the cylinder and a feeler gauge. Swinging the gauge from the piston to the deck can be tricky. The two measurments differed by .005. If the mains need to be honed have that done first. The align hone may slightly adjust the relationship between the piston and deck.
On line engine calculators indicated that my deck clearance would be .010 but it measured .015. Measure (twice).
After everything is machined do a full assembly and run the clay test to verify your piston to valve clearance.
Dale Shearon
68 Mustang 6394
Old 11-06-2019, 07:31 AM   #4
richie 2
Liked 205 Times in 93 Posts
pre assemble, measure & deck accordingly....rod length & crank stroke can be different between cylinders. get the average distance, same heigth on both decks. I just install the oil rings to do this...
richie 2 is online now   Reply With Quote
Old 11-06-2019, 09:46 AM   #5
carl hinkson
Liked 18 Times in 10 Posts
Good thing I have never had to preassemble engines to machine the decks.
carl hinkson is offline   Reply With Quote
Old 11-06-2019, 05:06 PM   #6
Tom Moock
Liked 10 Times in 6 Posts
427FE Are you asking about stock or superstock, there are rules for stock on compression height { pin to top of piston]
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 11-06-2019, 06:23 PM   #7
I wondered the same,Tom.
You can't machine the top off a Stock legal piston. The brand and part number has to remain intact. You can do anything you want to a Super stock piston top, as long as it looks kinda the same as original ;-)
Old 11-07-2019, 03:52 PM   #8
427FE
427FE's Avatar
stock, fellas
Pat Clemente
#1427 B/S
