Old 11-11-2019, 03:10 PM   #1
68Coupe
Default Question about oil and filter
building a 408W bracket motor 12.5:1 compression and hydraulic roller cam. going in an 1/8th mile footbrake care.
just wondering what everyone runs for oil and filter
68Coupe is offline   Reply With Quote
Old 11-11-2019, 05:25 PM   #2
John Dinkel
Liked 263 Times in 68 Posts
Default Re: Question about oil and filter
Amsoil, Valvoline, Mobil 1. Wix filters
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 11-11-2019, 05:31 PM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
Lightning racing oil and system 1 oil filters. I don't use any passenger car oil or filters on my race engines.
Mike Pearson 2485 SS
Old 11-11-2019, 05:45 PM   #4
Robbie Welch
Liked 262 Times in 124 Posts
427 windsor Schaeffers 20-50 Wix filter with a Melling select oil pump has 62lbs cold 58 hot
Old 11-11-2019, 05:47 PM   #5
jmcarter
jmcarter's Avatar
Liked 3,199 Times in 977 Posts
WIX/NAPA and Valvoline VR1 Racing Oil (no passenger car oil). Have used Mobil 1 Full Synthetic in bracket motors without issue but no way turning 8K thru the lights.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 11-11-2019, 05:51 PM   #6
Eman
Liked 133 Times in 76 Posts
Research what your cam/lifter manufacturer recommends I have heard hydraulic rollers are picky on oil weights. For a Filter Wix is a good filter and I'd look into Motorcraft. They used to be top of the line, don't know who makes them or what the ratings are.
Old 11-13-2019, 08:09 PM   #7
Todd Gross
Liked 54 Times in 24 Posts
If you're building a Hydraulic Roller Engine, I'd suggest using Johnson Lifters, the short travel Race versions. With the correct Valve Springs are stable up to 8000 RPM and higher.
As for oil, a good Racing Synthetic, such as JR1, HPL , Red Line.
If your bearing clearances allow, use a 5/20 or 5/30 weight. The lighter weight returns to the pan quicker and disperses air bubbles quicker as well. Also the lighter oil may protect better than a heavier oil that could be compromised with aeration.
And... WIX Racing or Moroso Oil Filters
My 2 cents.
Todd Gross
3323 FS/E,F
Todd Gross is offline   Reply With Quote
Old 11-15-2019, 07:12 PM   #8
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
My 2 cents.
I use Mobile One 0-20 Weight
Not road racing and figure wears engine less with all the cold starting.
