#31 |
Liked 58 Times in 16 Posts
Working brake lights from a mandatory, non-bypassable switch. So we can see who is hitting the brakes and when. Plus it could eliminate line lock and launch control starts. Brake lights should be on when you start, and not on until AFTER you cross the stripe!
Overkill is Under-rated |
#32 |
Liked 704 Times in 281 Posts
First part of this idea would make fast cars have an advantage.
#33 |
Allow TruStart and crank triggers. Get rid of E-shift.
#34 | |
Allow more non -Stock electronics?
#35 |
Liked 62 Times in 29 Posts
Allow the LT1 engines to toss that Opti Junk in the garbage where it belongs and either do CNP or a "normal" distributor. They are already allowed a crank trigger and aftermarket ECM's.
#36 |
Liked 129 Times in 53 Posts
Though I'm generally against anything turning a Stocker into a SS'er I would like to see Crank triggers allowed, especially now when more and more Cars/engines that have modern fuel/spark systems find the way into the mix of older cars it would be nice to at least be able to eliminate the irregular timing you often get with more normal setups going through timing chains(of more and more questionable quality) dist.gears etc.
#37 | |
Oh, wait. Here's three different 305, 4bbl. Malibu wagons that won Divisionals this year, with irregular timing..How do you suppose that happened?
#38 |
Liked 118 Times in 41 Posts
![]() 1st round at pomona, 2 races trustart would have changed the outcome
U/SA 79 Mustang |
#39 |
Liked 1,436 Times in 299 Posts
I don’t think you can draw conclusions from current races without really knowing more than what is on line. If tru start was in play, surely any racer would know that and adjust how they drive race etc.
James Schaechter 3163 STK |
#40 |
Banned
Liked 235 Times in 110 Posts
The non OEM lifters cost a bunch to survive the out of this world spring pressures !
