Old 11-15-2019, 07:07 PM   #41
Marty Knox
Liked 44 Times in 19 Posts
Default Re: What Stock rules would you change?
UUUUUGGGGGHHHHH, 1973-4-5? (a little help here)
All of the Stockers became SSers and Stock Eliminator became "PURE" Stock.
Not really a fun time to have a Stocker.
1972 was the first year the Pure Stocks became Stock and Super Stock expanded dramatically.
I ran a 65 Bel Air 4 door sedan with a 230 and a 3 speed in O/Stock.
Best time was a 17.6 at Island.
Marty Knox 3071 STK
Marty Knox is offline   Reply With Quote
Old 11-16-2019, 12:28 AM   #42
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
The non OEM lifters cost a bunch to survive the out of this world spring pressures !
The cost alone would be tolerable, it's the damage they do when hard or hardened parts break.
Old 11-16-2019, 08:32 AM   #43
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,388 Times in 504 Posts
Without the crank trigger you can't get a clean signal to the computer. I have spent lots of time and money trying to shield wires, have clean grounds, Magnecor plug wires, etc. but that stuff doesn't work. My tach signal is awful on the data logger and RPM jumps all around especially near finish line. Can't take advantage of my NHRA Accepted EFI system that does almost everything based on RPM. How will I ever get my E-shift to be accurate with this messy tach signal? I know I should have built a different combo silly me.
Mr Clean, You 're probably right. You can't win a thing with that irregular timing.
Oh, wait. Here's three different 305, 4bbl. Malibu wagons that won Divisionals this year, with irregular timing..How do you suppose that happened?
There's a late model GM in Division 1 that won 5 of them with regular timing, and great driving.
PS some rule changes I forgot: Fix the following stupid indexes
K/SA to 12.60, L/SA to 12.75, M/SA to 12.90 and so on..
oh yea, NHRA.TV on Thursdays should be a rule too!
'65 Mustang SS/L & L/SA
Old 11-16-2019, 09:59 AM   #44
Bob Don
Bob Don's Avatar
Liked 905 Times in 193 Posts
50 points for setting a record.
Bob Don 128 SS
Old 11-16-2019, 10:23 AM   #45
Race Clean
Liked 129 Times in 53 Posts
No Headsup with newer cars??
Race Clean is offline   Reply With Quote
Old 11-16-2019, 12:00 PM   #46
Talking Re: What Stock rules would you change?
I suppose "Mr Clean" has that option..Can't beat them..Try joining them
Old 11-16-2019, 12:10 PM   #47
Bobby , You have an E-shift on a 302? See post # 59 on the Enforcement thread.
Totally agree on the index change.
Old 11-16-2019, 02:25 PM   #48
Bobby Fazio
[QUOTE=Mark Yacavone;601930]Bobby , You have an E-shift on a 302? See post # 59 on the Enforcement thread.
No I’m joking I think it’s dumb and I don’t use it. I use B&M hammer and miss shifts perfectly fine on my own lol.
Old 11-16-2019, 04:37 PM   #49
John Bender
Liked 61 Times in 12 Posts
The 2 year change the belts. The 5 year change the trans shield. Is that piece of equipment really going to go bad? And enforce the rules that are already in the book.
John Bender, 1969 E/SA
John Bender 1969 STK
John Bender is offline   Reply With Quote
Old 11-16-2019, 05:50 PM   #50
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
I had a similar problem with my Racepak. I don't know about the Magnecor's but I put a new set of the MSD Super conducters on mine and the rpm trace cleaned right up.
Dave Noll, EF/S ,?/SA 6526
