Old 11-20-2019, 08:57 PM   #31
HP HUNTER
Liked 373 Times in 129 Posts
Default Re: Mopar 383 Connecting Rods
Originally Posted by Tom Broome View Post
No, but you double the length. Makes it easier on the operator.
I like to finish the rods in pairs as they will run in the engine. Does it make a difference? I dunno....makes me feel good.
Its also how you keep the mandrel true, its always about working the mandrel when honing.
Old 11-21-2019, 08:15 AM   #32
Liked 10,968 Times in 2,261 Posts
''The cap cutter should cut the parting line perpendicular to the sides. Therefore we need to prepare the sides, to the best of our ability, before we cut the parting surfaces.''
The best way I have found to make thrust sides close to 90* to the bore is to make a mandrel and face each side of the rod on a lathe. The mandrel will have one rod on it for balance while the second the rod is being cut.
So how much rod side clearance is too much?
Old 11-21-2019, 02:04 PM   #33
Glenn Briglio
Glenn Briglio's Avatar
Liked 976 Times in 311 Posts
Why bother with 40-50 year old stock junk when there are so many new rods available.By time you magnaflux, check for straightness, rebuild with better rod bolts, and bush the small end you could buy much better newer rods. And yes I've rebuilt stock rods with better rod bolts and couldn't keep the housing bores round.
Old 11-21-2019, 02:16 PM   #34
Tom Broome
Liked 88 Times in 43 Posts
I agree, back in post #13.
Tom Broome is offline   Reply With Quote
Old 11-21-2019, 02:24 PM   #35
Tom Broome
Preaching to the choir.
But it seems that guys who are hot rodding big block Chevys and MoPars tend to stick with stock rods. Small block Chevys....you can't give away stock rods....literally. Come by if you want some.
Old 11-21-2019, 03:03 PM   #36
James L Miller
Liked 25 Times in 16 Posts
I got an e-mail from Molnar rods that Tom Molnar will submit his 383 Mopar rod (w/BBC big end, stock length) to NHRA for SS approval. Nothing for the Stocker guys with the 383. I've been told that Hale is trying to get Manley to run another set of his rods (stock pin and big end sizes).
Mopar 2 Ya!
Old 11-21-2019, 03:12 PM   #37
Glenn Briglio
Y'all need to teach your customer's what is needed and better for them.....lol
Old 11-22-2019, 10:06 PM   #38
HP HUNTER
What is this instrument used for in a machine shop?
Old 11-23-2019, 07:39 AM   #39
Glenn Briglio
Could be to check connecting rods for straightness.
Old 11-23-2019, 09:43 AM   #40
HP HUNTER
Another angle of view.
