Old 12-04-2019, 09:17 PM   #1
SSDiv6
Liked 1,600 Times in 583 Posts
Default NHRA 2020 Rule Amendment SS Intakes???
Was just looking at the new NHRA 2020 Rule Book amendment prohibiting spacers between the intake and the cylinder head.
They already allow sheet metal intakes and also two piece intake manifolds split in the middle in the class so what is the difference in having a spacer between the intake and cylinder head?
This will effect many cars including Mopar 383 with Chevy intakes, Ford FE with 351C intakes and AMC with Mopar intakes running spacers to fit these intakes.
Old 12-04-2019, 11:06 PM   #2
Bob Sherwood
Liked 388 Times in 60 Posts
Default Re: NHRA 2020 Rule Amendment SS Intakes???
This has more to do with heads than intake manifolds.
Bob Sherwood is offline   Reply With Quote
Old 12-05-2019, 09:48 AM   #3
Ralph A Powell
Liked 225 Times in 136 Posts
You mean adapters?
Old 12-05-2019, 10:51 AM   #4
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
I don't see anything prohibiting an extremely thick, metallic-core intake gasket.
S/ST 51
S/C 53
Old 12-05-2019, 11:32 AM   #5
Steve Stasko
Liked 274 Times in 143 Posts
An MLS Head gasket is essentially a spacer with a gasket on each side when you get into the thicker gaskets (.050"+). How is a "metallic-core" intake gasket any different?
Old 12-05-2019, 12:01 PM   #6
Jeff Stout
Liked 706 Times in 283 Posts
Weld the spacer to the intake?
Old 12-05-2019, 12:13 PM   #7
Sean Cour
Sean Cour's Avatar
Liked 124 Times in 39 Posts
This has more to do with lazy engine "assemblers" than anything!
Sean Cour
T6066 ladle
Sean Cour is offline   Reply With Quote
Old 12-05-2019, 01:38 PM   #8
Lenny5160
Lenny5160's Avatar
It was a joke, a-la "that isn't a spacer, Mr. Tech Guy. It's just a gasket with a very thick aluminum core."
S/ST 51
S/C 53
Old 12-05-2019, 02:13 PM   #9
Bryan Worner
Liked 535 Times in 86 Posts
Oh, but who could you be referring to????
Bryan Worner is offline   Reply With Quote
Old 12-05-2019, 04:58 PM   #10
Dallas Kelly
Liked 85 Times in 21 Posts
It seems clearly apparent who NHRA is focused on with this arbitrary change to one of the longest standing tenants of Super Stock eliminator racing. "Any intake manifold permitted provided unit is of the same configuration as original for carburetor used and will fit under original factory-produced, installed hood" has been one of the basic corner stones of Super Stock Rules since inception of the eliminator, dating to the early/mid-1970's. I'm just guessing but my money says they (NHRA) will expect the affected racers to be grateful that they "only" decided to make this change after almost 48 years of careful consideration.
Dallas Kelly is offline   Reply With Quote
