#11 |
Liked 2 Times in 2 Posts
Capri if that is all they will do, then that is it. This is the kind of information I am needing to make a decision. Let us not forget that they started at 154 so that is a good improvement. I would love to hear some better numbers but?
#12 |
Liked 27 Times in 14 Posts
Key words being "289 heads" Kip had "special" 289 heads..............
#13 |
Liked 373 Times in 129 Posts
Heres the flow sheets on Kips 289 heads. Tested on a SF 600 sealed 4.00 bore @ 28 inches. I also have a (289) flow test from another well know Super Stock head porter as well peaking @ 215 CFM.
#14 |
#15 |
I have a little hope after seeing these numbers, I wonder what/whose cam was installed?
#16 |
Is anyone up to this post?
#17 |
With 3000 views I would have thought that more people would have responded.
#18 |
Liked 805 Times in 245 Posts
Don't take it that people are being rude, but do bear in mind that most people in class racing have a limit on how much info they are willing to divulge particularly in the area of heads and manifolds. I get calls from people quizzing me about my combo, I am willing to discuss the general info but I'm not going to discuss the fine points. There is a reason why the Pro Stock boys cover up their intakes and do their best to block off their pit areas. Personally, I think people roaming around during teardowns is not OK either, people work hard on their combos and allowing people to randomly snoop is not acceptable.
Jim Caughlin SS 6019 |
#19 |
Really don't see what more you would need to know, you've got the flow test from the fastest 289 Ford SS/L on the planet........I wouldn't worry about more opinions, I'd just get to work. You also know it made 467 HP @ 7400 RPM STP on a SF dyno. First hand information.
#20 | |
Liked 165 Times in 60 Posts
