Old 12-17-2019, 10:18 AM   #11
Mike Rietow
Mike Rietow's Avatar
Liked 30 Times in 16 Posts
Default Re: Reaction time question
Mike,
Hope you spend wisely.
Like me, looks like you could use a new camera
Good Luck
Merry Christmas
Mike A114
A spectator text me that video LoL, Good call though! Merry Christmas to you and your family as well! Thank you
7x S/Pro 'Sunshine" http://ottm.store
https://youtu.be/I8QWEaqeFRw
Mike Rietow is offline   Reply With Quote
Old 12-17-2019, 12:59 PM   #12
gfbdiesel
Liked 2 Times in 2 Posts
why don't you put a delay box in and run the same tire and button you have? just adjust the delay box to reaction times
gfbdiesel is offline   Reply With Quote
Old 12-17-2019, 01:02 PM   #13
Mike Pearson
Mike Pearson's Avatar
Liked 1,985 Times in 598 Posts
Sounds like you are not allowed a delay box in that class. Us super stock guys use a long stroke button to slow down to keep from going red. Just N Time or Biondo terminator would be some to try. I also use the leave chip to control the reaction time on my car. front tire pressure is also another way to adjust.
Mike Pearson 2485 SS
Old 12-17-2019, 03:01 PM   #14
Mike Rietow
That's not a bad idea only delay boxes aren't allowed in the index classes at Lights Out let alone a heads up class otherwise I'd have no objection. We're kinda getting pressed for time with this car, I forgot to mention the class is limited to a 4150 carb and intake. We just got the carb but are a little behind on the intake as the engine was already fitted with a 4500 carb and intake when the rules for this new class came out. I do the engine and transmission assembly, suspension tuning. I don't want to spin the other guys out with the issue with the 400 pro tree at Lights out after having been double O on the .370 tree we run on local just yet. Figured I'd get some idea's together in here I can easily access to review when the right time arises. We're waiting on a set of steel shaft rockers from jesel now. Depending on when they arrive will determine if we're gonna make a couple test laps with the 4500 intake and carb while getting the 4150 intake work underway. We have a set of jesel aluminum shaft rockers on it now we've made several pulls on the dyno with but we're getting those off of there as a preventative measure. An adjustable button or delay box will spin these guys out, with all the other obstacles at hand in getting the car ready. It'll end up a last minute fix I throw on this thing with some good Idea's in here I can review back to quick, as I am forecasting it based on past experiences.
