Old 12-24-2019, 12:15 PM   #1
leon philpot
Liked 2 Times in 2 Posts
Default 305 crankshaft {stocker)
can anyone tell me the crankshaft weight
the one in my motor weights 54 lbs.
thanks
leon philpot is offline   Reply With Quote
Old 12-24-2019, 01:29 PM   #2
Mike Jones
Liked 684 Times in 289 Posts
Default Re: 305 crankshaft {stocker)
You didn't say who made it, but you should check the rulebook: "Stock OEM or NHRA-accepted aftermarket crankshaft mandatory. Aftermarket crank must retain OEM configuration (i.e., billets, knife edging, etc. prohibited). Lightening of crankshaft other than normal balance job prohibited. Aftermarket SFI Spec 18.1 harmonic balancer mandatory in AAA/S through G/S and AAA/SA through G/SA. See General Regulations 1:2. "
….and you can sort through the link below
Good Luck and Merry Christmas
http://www.nhraracer.com/Files/Tech/...edProducts.pdf
Old 12-24-2019, 06:14 PM   #3
Billy Nees
Umm, not for nuthin' but check out a 267 crank.
Billy Nees 1188 STK, SS
Old 12-25-2019, 12:19 AM   #4
Bench Racer
Liked 99 Times in 21 Posts
If this man says it,, you better listen and look. Don Jackson
Bench Racer is offline   Reply With Quote
