Old 12-27-2019, 10:27 PM   #1
vic guilmino
Liked 56 Times in 21 Posts
Default 02s in header
How far from the end of header should the 02 be placed
Vic Guilmino 1129 STK
Old 12-28-2019, 12:07 AM   #2
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default Re: 02s in header
most are as far back in the collector as you can get,, but a true reading should be in the primary tube of the leanest cylinder for your combo
collector readings will be leaner than in a primary tube ,,so when doing a dyno session apples for apples
if your on the dyno use the same sensor location
Old 12-28-2019, 01:30 AM   #3
Sean Cour
Sean Cour's Avatar
Liked 125 Times in 40 Posts
Two inches beyond the merge. If in SS, you want them pre the pan evac.
Sean Cour
T6066 ladle
Sean Cour is offline   Reply With Quote
Old 12-29-2019, 09:39 PM   #4
HR9121
HR9121's Avatar
To add to what Sean said, 2" beyond the merge and it helps if you have somewhere in the neighborhood of 14 to 18" of collector beyond that.
James Williamson
W200 J/SA. SS/JA
Old 12-30-2019, 11:09 AM   #5
Signman
Liked 269 Times in 99 Posts
Within 20 inches of the exhaust valve will be more accurate see less fresh air.
Old 12-30-2019, 12:05 PM   #6
Shadylane
Shadylane's Avatar
Liked 173 Times in 52 Posts
Tagging onto this thread. I put a different set of headers on my car that use slip tubes. I noticed the tube my sensor is in is leaking slightly. What can I use to seal it?
Kelly
Shadylane is offline   Reply With Quote
Old 12-30-2019, 05:26 PM   #7
Jim Kaekel
Liked 535 Times in 110 Posts
Permatex offers a high heat/sensor safe sealant.
Jim Kaekel 3836 STK
Old 12-30-2019, 08:03 PM   #8
vic guilmino
My are 9 from the end of collector
Old 12-30-2019, 10:23 PM   #9
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
Mine are about 4” from the end. Never dynoed it, found the happy spot (fasted tune up down the track) and monitor it now for changes.
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
