Old 12-25-2019, 12:09 AM   #21
Tim Barrett
Liked 472 Times in 72 Posts
Default Re: keep working on your stuff
As the topic says "Keep Working on Your Stuff" would fall into the guy who is trying to run on a budget,or as we are doing trying to get back into the swing of things before dumping tons of $$$ into our combination. 4 and 3 years ago we could barely run the G/SA 12.00 index. We finally blew that engine at 6500 rpm's and decided to build my own engine. Last year we had a best of 11.292 at 115 mph on our own engine. CP Pistons,Total Seal Rings,Bullet Cam and several other pieces. This year we made a cpl subtle changes,can't change many without testing each change. Hopefully we can pickup at least 1 to 2 tenths by the end of the year which will get us to 11.10s. We will keep working on our stuff till there's no more that I can do myself but for now it nice to know I can build a 255hp 350 that will run 7 plus under the index for under 5 grand.
Tim Barrett is offline   Reply With Quote
Old 12-25-2019, 09:20 AM   #22
Liked 10,968 Times in 2,261 Posts
Sometimes the dyno is the best place to spend. It will be your report card and road map.
Old 12-25-2019, 11:52 AM   #23
Dan Walcott
Liked 92 Times in 26 Posts
I was at the dyno last week, showed improvement, made some changes, and going back next week for some more pulls.
Dan Walcott is offline   Reply With Quote
Old 12-25-2019, 06:43 PM   #24
Dan, It sounds like you have the needle in deep........don't it feel good!
Old 12-26-2019, 10:41 AM   #25
Dan Walcott
Yes it does!! And I like it !! I started this project in 1981, to stubborn to give up on it, (admitting I'm not the sharpest knife in the drawer) , I will keep plugging away , looking for a tidbit here and a crumb there.
Enjoy the Holidays , 2020 is just around the corner..
Old 12-27-2019, 12:58 PM   #26
Patric Fox
Patric Fox's Avatar
Liked 11 Times in 8 Posts
Good for you G, I know with your combination you have to work hard. Can't go out and buy go fast parts and bolt them on. I am in the same situation, working full time, travel with work, and working on customers stuff before the race car. But I am going to keep working just like you. Good luck this coming year.
Patric Fox is offline   Reply With Quote
Old 12-28-2019, 10:15 PM   #27
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Patrick Thanks and to the fellow racers who replied to this post,also to the people who helped in finding more performance ,i am waiting for my crank to comeback from balancing as the final part needed to start reassembly
Of the engine with hopes of testing in late April ,,,first race is @ Atco in may
