looking for help suggestions
Liked 1,946 Times in 587 Posts
What is the issue?
Mike Pearson 2485 SS |
Banned
Liked 179 Times in 89 Posts
Does it go left or right off line?
This suspension always is a struggle for me for as simple a deal that it is!
Car usually works well and leaves straight. Every so often it will tend to go right, and the rare occasion when it spins it goes to the right.
if the car is working good and goes straight most of the time then I would say maybe you are out of the groove when the car goes right. There are only a couple of reasons that a ladder bar car will go left or right at the hit. first is the rear is not square in the car. Second the front holes in the ladder bar mount are worn or elongated. Check both very carefully. Typically preload is not needed if the car is set up properly. My car I ladder bar and coil over. One other thing is I don't set the car up with the shocks on it. I have some struts that I made to go where the shocks mount the same length that I run the shocks. Set it up neutral with the struts then re install the shocks and set the ride height of the shocks exactly where it was with the struts.
Liked 312 Times in 175 Posts
Check that the rear is square in the car, measure circumference of slicks and compare.
Liked 30 Times in 16 Posts
That's really not unusual OP, the rotation of the rear-end on low hp cars controls the dynamics of the chassis. A little pre-load takes care of that, but pre-load is a last resort. There's other avenue's besides pre-load depending on what we're working with. Do you have double adjustable coil-over shocks on the back of the car? What kind? How many clicks of adjustment?
Do you have double adjustable struts/shocks on the front? or single? or no adjustment up front? |
Liked 71 Times in 38 Posts
If it’s only on occasion , are both tires getting an equal burnout and heat? Out of groove like previously mentioned would make sense too.
If the rear of the car has a tendency to go right on the burnout. it's wearing the left rear tire. If this is the case, this can be taken cleaned up with a shock adjustment, if we have D/A shocks in play on the car.
