Liked 7 Times in 6 Posts
I just got a couple Moroso 23991 400 watt probe type heaters and I've been told they can scorch the oil. I notice that the Stefs is a much lower wattage. Which oil/trans oil heater do you use? Thanks for your advice.
Liked 799 Times in 236 Posts
For engine oil, a Kats watt magnetic heater...steel pan, of course. For the trans, a Zero Start heater with a 1/2 NPT bung welded to the trans pan. -Al
"That'll never work....." Last edited by Alan Nyhus; 01-03-2020 at 03:57 PM. |
Liked 240 Times in 112 Posts
Got a few of the Kats 300 watt magnetic heaters. Gonna have to get something different for the EF/S car, Aluminum pan.
Dave Noll, EF/S ,?/SA 6526 |
Liked 173 Times in 52 Posts
I’ve used the Moroso external heating pad for a couple years now. Takes about 30 minutes to heat the oil. Sticks on, they have different sizes or a model that attaches with springs.
Moroso 23996 - Moroso External Heating Pads Kelly |
#5 | |
Liked 172 Times in 81 Posts
Jim Mantle V/SA 6632 |
Liked 167 Times in 81 Posts
I siliconed the Moroso heater to the bottom of my aluminum pan worked great, but would leave it on for only about 30-45 minutes.
Tim Schmackpfeffer 762 SS |
#7 | |
I tried a stick on pad but when I saw smoke coming out of the diaper after a few minutes, I took it off. |
Liked 333 Times in 180 Posts
Definitely look at the Stef's heaters ---either the pad or the in the pan style---the in the pan style is for use in OILS --the Moroso style heater is for WATER---Go to Stef's website read about their products--- other suppliers may make a similar product but the Stef's style will not scorch the oil because of its design---the only difference between using it in a steel or aluminum pan is the bung that you weld into the pan steel for a steel pan and aluminum for an aluminum pan-- FED 387
#10 | |
Liked 133 Times in 76 Posts
