#11 | |
Liked 7 Times in 6 Posts
Heater element designed specifically for heating oil; does not scorch or boil like "converted water heater" designs 212 watts of power raises temperature of 12 quarts of oil 60 degrees F in about 25 minutes 400 watts of power, 110-120 volt rating Aluminum, 1/2" -14 NPT weld-in bungh and 3 ft. cord included Length of heating element is 4-3/4" from fitting to tip |
| Liked |
#12 |
Liked 335 Times in 182 Posts
I know which one I'd use and it's the same one we have used in multiple engines--As far as the pads go we have used them ONLY to preheat the differential never the oil pan itself-- Your choice use what you like if it works great for your application terrific. AS LONG as you use the type that is totally sealed unlike the one in the picture you should be OK also remember the "2 piece" type the connector has a habit of loosening up and you have to be aware of this constantly check to make sure its screwed on tight ---FED 387
#13 | |
Liked 800 Times in 237 Posts
"That'll never work....." |
#14 |
Liked 4 Times in 1 Post
I have used the pad and the phillips type oil heaters. The phillips is the way to go for me. Never had a problem with it.
| Thread Tools | |
| Display Modes | |
