Old 01-17-2020, 06:40 PM   #11
Rory McNeil
Default Re: Header tether needed?
Also many race style headers are multiple tube, and need to be installed 1 piece at a time. Take a look at the headers on most 390 & 428 Mustangs and Fairlanes. No way to install those headers if they are all 1 piece, (hell, its a major PITA, even with 8 separate tubes!)
NHRA 6390 STK
M/S 85 Mustang
Rory McNeil is online now   Reply With Quote
Old 01-17-2020, 07:30 PM   #12
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
PITA ? bread ? or Politically Incorrect Technical Answer ?
MAURICE BLENDHEIM is offline   Reply With Quote
Old 01-17-2020, 08:23 PM   #13
JeremyDuncan
Liked 355 Times in 80 Posts
It's an widely used acronym.
PITA= Pain in the ***
JeremyDuncan is online now   Reply With Quote
Old 01-20-2020, 08:50 AM   #14
terry1
Liked 24 Times in 13 Posts
Smile Re: Header tether needed?
Not long after the "tether" rule came into effect, at a race in Epping, a guys "tether"
came off.There is even a video of that some where!
The next thing will be a "tether" to hold the "tether" on!!!
Then a "tether" to hold the "tether" to hold the "tether" ....................
Terry K
terry1 is offline   Reply With Quote
Old 01-22-2020, 03:07 PM   #15
Jim Caughlin
Liked 805 Times in 245 Posts
Terry K
So explain the logic here, regardless of my experience (and welding skills), NHRA is OK with me building my entire chassis in my backyard but when it comes to header tethers I need to buy a $125 "NHRA certified' piece of cable and two hose clamps that I could have bought from Grainger for maybe $20? Seems risky to me, maybe they should have to be replaced every two years?
Jim Caughlin is online now   Reply With Quote
Old 01-22-2020, 07:17 PM   #16
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
How long has this "weld-on" tether been accepted?.I thought the reason for using the T-bolt clamp on the pri.pipe and collector was to prevent the old style tabs with 1/4" bolts and lock nuts from breaking off at the weld and the collector coming off.I know you still use the original tabs too, but how is this any better?...gsa612
Old 02-01-2020, 11:48 PM   #17
Sean Cour
Sean Cour's Avatar
Liked 125 Times in 40 Posts
Originally Posted by bykr View Post
After doing a search on here and not really finding a definite answer I'm wondering if I need a tether on a collector extension that has a three bolted flange. The Collector is welded to all four header tubes(street style header).
So lemme get this strasight......you’re on the forum, telling everyone how knowledgeable you are in manifold/head engineering, but can’t figure out the header tether rule?
Sean Cour
T6066 ladle
Sean Cour is offline   Reply With Quote
Old 02-02-2020, 12:58 PM   #18
bykr
Liked 167 Times in 81 Posts
Far from that! Just been a racer a long time in some fast cars and using some common sense. New to the SS game so I'll probably be asking some dumb questions
Tim Schmackpfeffer 762 SS
bykr is offline   Reply With Quote
