Old 01-23-2020, 06:10 PM   #41
Tom Broome
Liked 88 Times in 43 Posts
Default Re: Question on loosing fuel pressure going down track.
Originally Posted by Jeff Stout View Post
No foam in cell. I'm going to bypass filter and retest filling time in bucket. I did notice once after shutting off car the cell acted like it was under a vacuum when I tried taking cap off. I will look at vented line to see if it collapsing or kinked. All lines,fittings,filter,pump,cell were all brand new.
Here in the Southeast. it's not unexpected to find mud-dauber plugs in things like a fuel cell vent.
Tom Broome is offline   Reply With Quote
Old 01-23-2020, 07:48 PM   #42
Kirk Morgan
Liked 81 Times in 45 Posts
A lean miss-fire will show a rich condition due the un-burned fuel leaving the combustion chamber.
Kirk Morgan is offline   Reply With Quote
Old 01-23-2020, 08:09 PM   #43
cmracing
Liked 62 Times in 29 Posts
A wideband sensor will show a lean miss-fire as a lot of excess oxygen in the system, fooling you into thinking the engine is running lean.
A severely rich mixture will also show as a lean condition on a wideband sensor.
Spark plugs and header tubes don't lie.................. But the widebands can.
cmracing is offline   Reply With Quote
Old 01-23-2020, 09:59 PM   #44
Ed Wright
Ed Wright's Avatar
A severely rich mixture will also show as a lean condition on a wide band sensor.
Been doing this many years, (not just my race car) I have never encountered that.
Misfires do look lean.
Ed Wright 4156 SS/JA
Old 01-24-2020, 01:51 AM   #45
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
YES, a mis-fire will show lean on a wideband sensor. All that sensor reads is oxygen, when there's a mis-fire, oxygen isn't getting used on that cycle so it passes through the engine un-used. A wideband sensor in a collector is seeing the average of 4 cylinders. If say theres a distribution problem in an intake manifold, the average of the 4 could show close to perfect, but with the bad intake it may have a severely lean hole. The better way to check would be to weld 8 bungs into the primary tubes of the headers and either install 8 sensors or rotate 1 sensor over 8 passes down the track.
Dave Noll, EF/S ,?/SA 6526
Old 01-24-2020, 10:10 AM   #46
Ralph A Powell
Liked 227 Times in 138 Posts
Have had very little spider plug fuel cap vents over winter.
Old 01-24-2020, 11:41 AM   #47
cmracing
Pull a plug wire off sometime and watch the wideband sensor. You will see the same thing happen as if you unplugged a fuel injector instead of pulling the plug wire.
The too rich showing lean though, that can be tricky to diagnose. A N/A engine will typically be falling on it's face though, but on a forced induction it can be misleading, therefore plugs and collectors are the best thing to determine the root cause.
Old 01-24-2020, 12:11 PM   #48
Jeff Stout
Liked 708 Times in 285 Posts
On my other car I use a 2 step and car goes rich staging with trans brake and 2 step. Takes about 1.5 seconds to clear up when released.
Maybe 2 types of misfires. One with plug not firing and car goes rich , the other if injected and injector does open then car goes lean? IDK
Jeff Stout is online now   Reply With Quote
Old 01-25-2020, 01:24 PM   #49
cmracing
Yes, the wideband can fool us if we don't use other methods to determine what is really happening inside the combustion chambers!
Just remember, a wideband sensor only measures oxygen inside the exhaust system, it knows nothing about fuel inside the pipe.
Old 01-25-2020, 03:21 PM   #50
Jeff Stout
Ok here is the fix. I bypassed summit inline filter and changed vent line on fuel cell. 1 gallon in about 40 seconds and today's pass with leaner secondary rods im at 5psi in high and went 12.1 afr. May night be perfect but improved .3 mph
I want to thank everyone for the suggestions as they were helpful in chasing problem.
