Old 01-29-2020, 01:08 PM   #141
Nick Heath
Liked 566 Times in 135 Posts
Default Re: NHRA 2020 Rule Amendment SS Intakes???
Originally Posted by Bob Smith View Post
So if I analyzed those blocks of text correctly, here's what's changed:
* Angle milling of cylinder head, exhaust and intake mating surfaces permitted.
* Additional intake manifold bolts holes permitted.
* Spacer plates between intake manifold and cylinder head permitted.
Old 01-29-2020, 01:43 PM   #142
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Good thing pinned studs are still legal......All the racers with them can breathe a sigh of relief...…..LOL
P.S. I did pin a lot of studs but it was at least 30 years ago and a lot more....
Rich Biebel
S/C 1479
Stock 147R
Old 01-29-2020, 03:45 PM   #143
Tom P
Liked 239 Times in 94 Posts
I am curious why it's always been worded as "must hold volume" and no mention of maximum.
"Cylinder head must be able to hold combustion chamber, intake and exhaust runner volumes per NHRA Specifications"
The way I interpret that is a five gallon bucket will hold a gallon but a one gallon bucket won't hold five. So ports can be larger than their spec but not smaller.
Obviously they want the combustion chamber to hold all of the 72cc or whatever spec is but they want that 205cc port to hold NO MORE THAN 205cc.
Why wouldn't they just say that?
A lot of the rulebook seems to have been written in 1952 and they added extra words instead of rewriting the whole thing. The previously mentioned pinned studs for example.
Old 01-29-2020, 08:10 PM   #144
Tom Broome
Liked 88 Times in 43 Posts
Yeah......about that. I also hadn't pinned any studs in a long time either. Racers moved on to better options.
Then......the Magazines and the Internet "Experts" convinced all these streetcar folks that they needed Vortec heads as a "budget" performance option. You put one more ounce of spring pressure or cam lift on those things. and the studs seem to fly out. Once they see that the guides have to be cut and new seals installed, there's no room in the "budget" for screw-in studs. Now pinning becomes an option again.
P.S. I can't describe how much I dislike pinning studs nowadays.
Tom Broome is offline   Reply With Quote
Old 01-30-2020, 10:23 AM   #145
bert powell
Liked 34 Times in 12 Posts
Who is going to be the first to take a bbc oval port head and mill 1" off the intake flange of head below the valve cover bolts? Should gain 50-60cc to open up the port.
bert powell is offline   Reply With Quote
Old 01-30-2020, 01:17 PM   #146
bykr
Liked 167 Times in 81 Posts
Yeah, after the crying, NHRA backing down leaves the door open for more "innovation".
Tim Schmackpfeffer 762 SS
bykr is offline   Reply With Quote
Old 01-30-2020, 02:49 PM   #147
SSDiv6
Liked 1,594 Times in 583 Posts
Bert,
Do you even know what you are talking about?
Gain 50 to 60 cc's when the rules allow you to port, epoxy and epoxy the cylinder heads?
Old 01-30-2020, 02:58 PM   #148
Joey Bohannon
Liked 61 Times in 22 Posts
Bert knows exactly what he is talking about! If they cc without the spacer plate there is a ton to gain. And if there wasn't gains to be had in port volume, then why do they make'm. Air speed can still be retained with more volume.
Joey Bohannon is offline   Reply With Quote
Old 01-30-2020, 03:40 PM   #149
SSDiv6
It is measured without the spacer and not all engines use a spacer. There is a lot more to to volume to make power with cylinder heads.
Old 01-30-2020, 05:03 PM   #150
bubski
Liked 165 Times in 60 Posts
Once again the "innovators" get there way !! Break out the 85b n mill away !! Can anyone guess whats next to come down the road ??
bubski is offline   Reply With Quote
