Old 01-30-2020, 05:10 PM   #151
bert powell
Liked 34 Times in 12 Posts
Default Re: NHRA 2020 Rule Amendment SS Intakes???
Bert,
Do you even know what you are talking about?
Gain 50 to 60 cc's when the rules allow you to port, epoxy and epoxy the cylinder heads?
If the port volume is measured without the spacer, you get to add all the spacer volume into the port. Very simple to understand. Make the rule that the port volume is measured with the spacer and I bet you wont see anymore of them.
bert powell is offline   Reply With Quote
Old 01-30-2020, 05:15 PM   #152
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
Exactly how do you do that with a sheet metal intake (and there are no plates) ?
Jeff Niceswanger 3740 SS
Old 01-30-2020, 05:27 PM   #153
nhramnl
Liked 358 Times in 83 Posts
Originally Posted by Joey Bohannon View Post
Bert knows exactly what he is talking about! If they cc without the spacer plate there is a ton to gain. And if there wasn't gains to be had in port volume, then why do they make'm. Air speed can still be retained with more volume.
Joey and Bert are correct. This is EXACTLY what Westcott did to build the monsters he and his dad ran in SS/AH.
Old 01-30-2020, 06:02 PM   #154
bert powell
You are exactly right Jeff, sheet metal intake would cover it up. So the rule of not cutting into the valve cover bolt and angle of +/-2 degrees would put some parameters to the rule.
As for it being legal per the rulebook, the no external modifications wording makes it illegal. Also, isn't there a sentence somewhere in rulebook that if it doesn't say you can do it, then you can't? Not sure about that but recall something like it.
I looked at a bbc head last night and roughly calculated the 50-60cc number using 1.75"x2"x1" but the port is oval not rectangular. So it would not be that big but bet it is 30-40cc. The advantage would definitely be bigger for bbc verses sbc.
Old 01-30-2020, 08:01 PM   #155
fredjohnston
Liked 55 Times in 14 Posts
The rule states the intake bolt holes must remain in original location. How can you cut 1" off the head and still leave the intake bolts in their original location? Or how about the valve cover bolt holes?
fredjohnston is offline   Reply With Quote
Old 01-30-2020, 09:02 PM   #156
SSDiv6
Liked 1,594 Times in 583 Posts
The spacer is just an extension of the intake runner. Just adding more volume to the intake tract does not make more power. As Jeff Niceswanger stated, you can do the same with the proper sheet metal or billet intake or even by welding a cast intake.
Old 01-30-2020, 09:25 PM   #157
Kevin Panzino
Kevin Panzino's Avatar
Liked 748 Times in 137 Posts
As for it being legal per the rulebook, the no external modifications wording makes it illegal.....
So per the rulebook, milling the deck surface of the head is illegal......
Old 01-30-2020, 10:01 PM   #158
l88427
Liked 17 Times in 8 Posts
Don't think so,Wescotts heads don't use plates and still retain the valve cover bolt holes...
l88427 is offline   Reply With Quote
Old 01-30-2020, 10:03 PM   #159
l88427
This!
Old 01-30-2020, 10:32 PM   #160
bykr
Liked 167 Times in 81 Posts
It is measured without the spacer and not all engines use a spacer. There is a lot more to to volume to make power with cylinder heads.
You just don't get it. So why do you think they're doing this? The guy that was doing it obviously thought it had an effect.
Tim Schmackpfeffer 762 SS
bykr is offline   Reply With Quote
