Old 02-03-2020, 05:40 PM   #41
Tex013
Liked 44 Times in 26 Posts
Default Re: Drag radial life/ max passes ?
Lenny ,
leaving @ 4500 , converter flash is 6000
Lower hole , bar is parallel to ground
Tex
Tex013 is offline   Reply With Quote
Old 02-03-2020, 09:37 PM   #42
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
I 60' about the same as you, and I've always been a top hole guy. It puts more downward force on the spring.
I've also never tried to leave at nearly that high RPM. If I'm hitting the top bulb I'm at 3400, and the bottom I'm tuning my light with RPM and usually end up at 2900 or 3000.
I could see the high RPM being a big part of your issue, or at least not helping.
S/ST 51
S/C 53
Old 02-03-2020, 10:36 PM   #43
Tex013
thanks Lenny ,
I have played with 2 step , higher has always been faster .
Maybe with the weight and tq of the 505 it just really wants the stiffer MT radial , at least off the brake .
I think best sixty on Hoosier is 1.44 , 1.42 on MT but more consistently also .
I run a .400 sportsman tree no box .
Thanks for your time and thoughts .
I will try foot braking , normally under 3000 with old 5000 converter . Otherwise save up and call my friends @ Summit .
Heres my class 1st qualifier , I am 5th? . The only Plymouth Pretty ordinary from my usual pass
It is a facebook link .
https://www.facebook.com/OVOplay/vid...epa=SEARCH_BOX
thanks again ,
Tex
Old 02-04-2020, 10:30 AM   #44
Lenny5160
Lenny5160's Avatar
For a guy who was concerned about tire life in the first post, that burnout was way, way longer than I would consider necessary.
What is the goal of the class that you run? I understand that a higher launch RPM will typically be faster, but do you need to be faster? If not, I'd bring the RPM down quite a bit to soften the hit.
S/ST 51
S/C 53
Old 02-04-2020, 04:26 PM   #45
Tex013
Lenny that has been my normal type burnout for ages . I have found if I do a small "haze" burnout the car will always spin . Go figure . But i could try less ? I am concerned the more i spin up the more chance of breaking something
The class is a 10.00-12.99 dyo . Usual story hit a goal you want to stay there .
I doubt i can run for a few weeks now , but I want to try foot brake again . When i dropped 2 step not just slower but converter felt like winding up a rubber band .
Tex
