Hello, newbie here looking for input on arb for 70 camaro stocker car wants to pick up left front on launch i have typical calvert setup on rear anyone make a bolt in setup?Thanks in advance Rooster
Liked 431 Times in 224 Posts
Have you tried adding preload to the passenger side Caltrac bar so it gets a little head start?
S/ST 51 S/C 53 |
Yes i have didnt seem to help maybe need to go more?
Liked 162 Times in 45 Posts
I think I would be looking very closely at the subframes connectors. How they are welded/bolted, are the tight and straight. How bout the roll bar and where it’s welded. An antiroll bar would be a crutch for this problem and might cure the problem at another cost. Arb might help a property working car but I think you need to find the root problem first.
Liked 239 Times in 114 Posts
It would be a good idea to scale the car with drivers weight in place . Corner weights help make the right decisions on chassis tuning .
Liked 280 Times in 139 Posts
I don't think an ARB is the answer with Caltracs.FWIW, I run a 71 Camaro BBC stocker,and have 1 turn preload on the pass.side and 1/2 turn on the drivers. Seems to leave level...gsa612
Thanks to everyone for the help i will be trying all tips that i have received and will let everyone know how it turned out this is the best site on the planet to get help from folks who have been there and done that! Rooster
Liked 805 Times in 341 Posts
I would check with Calvert, they may want to change springs. I don't see any reason you would need a sway bar if everything is correct with the Caltracs.
Great customer support from them. |
