Old 02-06-2020, 02:01 PM   #1
Dale Hulquist
Liked 351 Times in 76 Posts
Default Mineshaft ?
I understand that mineshaft conditions only exist when half the field is -.85, is that correct ?
Dale Hulquist
4006 Stk
4006 S/Stk
Dale Hulquist is offline   Reply With Quote
Old 02-06-2020, 02:11 PM   #2
JeremyDuncan
Liked 355 Times in 80 Posts
Default Re: Mineshaft ?
First bottom half qualifier must be -.850 or more under.
So half plus one.
JeremyDuncan is online now   Reply With Quote
Old 02-06-2020, 08:22 PM   #3
Dale Hulquist
Thanks Jeremy i wasn't sure, i thought it was just the top half had to be -.85 didn't know about first car on bottom half had to be -.85.
Dale Hulquist
4006 Stk
4006 S/Stk
Old 02-06-2020, 09:26 PM   #4
Mike Gray
Mike Gray's Avatar
Liked 699 Times in 202 Posts
Does the mineshaft rule only apply to 1 category at a time?
If stock is under -.85 and super stock is over -.85 does mine shaft conditions only apply to stock?
Since it's associated to excellent weather conditions shouldn't it apply to both categories even if only one has the first bottom half qualifier -.85 under?
Old 02-06-2020, 10:21 PM   #5
Mepprecht
Mepprecht's Avatar
Liked 68 Times in 26 Posts
Only works for one class. Unless both do it.
Mike Epprecht
94 caprice P/SA - SS/PA 265
Mepprecht is offline   Reply With Quote
Old 02-07-2020, 10:17 PM   #6
thomas sheehan
thomas sheehan's Avatar
Liked 75 Times in 29 Posts
I've been thinking about this... let the tops 3-5 guys fight it out for number 1 bye run. Everybody else that can run -.85 or better would be smart to avoid the -.85 threshold, (so the mineshaft never comes into play). Why give those fast guys a "free pass". Keep your car under the -.85 and let the AFHS work. Some need to slow or speed up to avoid or get a headsup (I understand that). But otherwise, there is no good reason to go -.85.... Look at stock this weekend - qualifiers #29, #30, #31 all went -.87 (which made it a mineshaft situation).
Did you ever see the games played by numerous cars that don't want to run -1.00. It should be just as rampant to avoid the -.85 at any race where great weather applies... use your head and maybe these fast cars won't get a free ride.
Tom Sheehan
SS GT/NA 1046
