Old 02-20-2020, 08:30 PM   #1
oldskool
oldskool's Avatar
Liked 747 Times in 362 Posts
Default SS Head Porting Rules ?
Copied this from a 2014 rule book.
"...Porting, polishing, welding,
epoxying, and acid-porting permitted. Grinding and polishing in
combustion chamber permitted..."
I know absolutely nothing about SS head porting.
Just by what I read in the rule book, I ASSUMED that most any mild street porting job would be legal, in SS.
BUT, a guy on another forum suggested that ANYTHING that increases the volume of a stock factory port is illegal. I mean, even just a mild gasket match will increase port volume.
I was just trying to figure what kind of head work it would take to build a low buck Pontiac SS engine, that would have just enuff power to run the index, or just slightly quicker.
There are several Pontiac shops which offer mild street porting jobs which increase flow enuff to make the required power.
So, for you guys who know, is mild porting illegal, even just a gasket match, if it increases the volume of a single port, even a little ?
I mean, the acid ported Stocker heads have larger than Stock volume ports, don't they ?
Need some technical clarification on what is & is not legal for SS heads.
Thanks !
Old 02-20-2020, 10:11 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,948 Times in 589 Posts
Default Re: SS Head Porting Rules ?
It just has to meet the published port volume in Cc’s for the head number that you are running. Both intake, exhaust and combustion chamber. If they are big after poring then you fill back in with weld or epoxy to get back to the correct port volume
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 02-20-2020, 10:45 PM   #3
oldskool
oldskool's Avatar
Wow ! So even a very mild gasket match would be illegal in SS, unless you added weld or epoxy to offset any material removed ?
So, is all the high dollar head work done just to change the SHAPE of the ports, rather the the size/volume ?
Or do the techs just sorta let it slide, like they must have been doing all these years for the acid ported Stocker heads. I assume that everybody knows those big power, 8000rpm Stocker heads, couldn't possibly flow that much, with completely untouched factory ports.
Old 02-20-2020, 11:02 PM   #4
Mark Ugrich
Liked 71 Times in 38 Posts
Look up the allowed combustion chamber and intake and exhaust runner volumes in the classification guide for the Pontiac engine you want to use. Then compare the volumes to what the head has in unmodified form.
Old 02-20-2020, 11:13 PM   #5
oldskool
oldskool's Avatar
So, those port volume limits are exactly the same for both stock & SS ?
Old 02-20-2020, 11:40 PM   #6
Mark Ugrich
No, porting is not allowed in stock eliminator. You need to find the volumes allowed in super stock for your particular cylinder head.
Old 02-21-2020, 01:07 AM   #7
72 goat
My experience with late model (7K3, 4X) heads is that from the factory the port size is smaller than the maximum allowed, and the chamber is larger than the minimum allowed. My (non professional) experience is that the heads can be milled to get to minimum cc's, and that bowl work can really improve flow.
72 goat is offline   Reply With Quote
Old 02-21-2020, 09:28 AM   #8
Alan Nyhus
Liked 799 Times in 236 Posts
Register to Dwight's site and you can find the accepted port volumes on anything that's in the NHRA books. It also shows the rest of the engine specs and classification.
The yellow highlighted area on the rt. is slick as it shows the different cars a specific engine came in. -Al
http://www.classracerinfo.com
"That'll never work....."
Old 02-21-2020, 09:29 AM   #9
Jim Hanig
Liked 99 Times in 49 Posts
Red face Re: SS Head Porting Rules ?
Generally the heads are smaller than the leagle size. Gasket match and short turn you should stay with in the list. Unless the heads have been acid ported.
Old 02-21-2020, 12:46 PM   #10
Ed Wright
Ed Wright's Avatar
Generally, after milling the heads to correct chamber CCs, the intake side requires milling so the manifold fits correctly. That takes a few CCs off the intake runners. Decking the block (sbc engines here) needs the same.
We gotta put those CCs back, right? :-)
Ed Wright 4156 SS/JA
