Old 02-21-2020, 09:11 AM   #11
Brian Fink
Liked 28 Times in 9 Posts
Default Re: 305 header size ???
The Jack Davis headers were 1 1/2 to 1 5/8 to 1 3/4 ;Stahl 1 5/8 were quicker . Jere recommended playing with extensions as opposed to a step design which I did .
Brian Fink is offline   Reply With Quote
Old 02-21-2020, 09:26 AM   #12
Billy Nees
Jere wasn't a real fan of stepped headers. He also wasn't a fan of merged collectors. He said, "if your car picks up with a merged collector then your primary tube is too big".
Billy Nees 1188 STK, SS
Old 02-21-2020, 05:19 PM   #13
Ed Wright
Ed Wright's Avatar
Yep!
Ed Wright 4156 SS/JA
Old 02-21-2020, 11:21 PM   #14
James Jeschke Jr
Liked 19 Times in 10 Posts
1 1/2” x8”Lg. to 1 5/8”Lg. x8” to 1 3/4” is the best I have found.
James Jeschke Jr.
#1603 I/S
James Jeschke Jr is offline   Reply With Quote
Old 02-22-2020, 08:47 AM   #15
Alan Nyhus
Liked 800 Times in 237 Posts
Originally Posted by 71novastocker View Post
What would be the best header size to run. The combo is 175/248. Thanks.
Are you looking for a conventional header or a tri-y?
"That'll never work....."
Old 02-22-2020, 09:14 AM   #16
71novastocker
Either just looking for ideas. Hoping I pick the correct ones.
71novastocker is offline   Reply With Quote
Old 02-22-2020, 09:43 AM   #17
Billy Nees
Ya know, you don't post with a real name so I can't tell if you're a Newbie or a veteran of Stock. If this is your first build, then good luck picking the "correct ones" the first time around. Heads, intakes, carbs and cams change over time and that will change the working range of this combo. Unless this is a "top shelf, best of everything" build by a known builder, who knows the combo, then I would stay away from a tri-y header to begin with.
Old 02-22-2020, 09:58 AM   #18
Alan Nyhus
A correctly done tri-y will make more torque and still run up high. It may not show as big a h.p. number on the dyno but may very well go down the track quicker. If you're willing to go further, cam changes can find more power and torque, depending on where you're at now with the cam numbers. Think of the tri-y's as a stepping stone because they are are also a considerable investment. Needless to say, we're talking about a really good set of stainless tri-y's here...something from Cal Elston, Performance Welding or someone that understands exhaust port dynamics, not a set of ebay special tri-y's.
Just my experience with them, FWIW.
For a conventional 4-1 header, I'd happily pick up the phone and order a set of 1 5/8" and go racing:
https://acpheaders.com/
Ben Line is a real craftsman and makes great headers:
https://www.headersbyben.com/
Old 02-23-2020, 10:45 PM   #19
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Ben is very good!
Glen DeMenge
1969 Camaro Stock Eliminator
MEXJOE is offline   Reply With Quote
