Old 03-02-2020, 08:27 PM   #1
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
Default What's your favorite tire pressure gauge, and why?
I'm in the market for a new gauge this season. The one I've been using came from the Hoosier guy at a divisional a few years back. When checked against a few other gauges last fall, it was pretty far off. Soooo, what's the best?
Paul Merolla is offline   Reply With Quote
Old 03-02-2020, 10:52 PM   #2
james schaechter
Default Re: What's your favorite tire pressure gauge, and why?
Get one you can recalibrate against a standard. I have older CSR ones. Then hold up well. I just checked them at the track Moroso display.
James Schaechter 3163 STK
Old 03-03-2020, 09:01 AM   #3
Alan Nyhus
Liked 799 Times in 236 Posts
Paul, I like this Intercomp. The illuminated face is a nice feature. It's accurate, repeatable, durable and made in the U.S.A.
https://www.intercompracing.com/4-ul...uge-p-196.html
"That'll never work....."
Old 03-03-2020, 09:57 AM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
One of the best is the Moroso 89552 gauge which is 1/2 % accuracy.
Unfortunately ,it's not the easiest to use since you need to keep it protected in it's case and it must be held upright .
That said, I use it to check and calibrate the 89592 0-15 # gauge I normally use. I check it at every race .
Most common gauges are a 2 % accuracy type ,which means a typical Stocker with 20 # of tire pressure in the Radial slick can be off plus or minus nearly 1/2 # .
Digitals can be ok and they certainly will survive the abuse they see laying on the floor in many cars, most are still 2% accuracy ,they still should be checked regularly . ......One bad thing about digitals is that when left in the heat of the car or direct sunlite the LCD display can become un readable .
Old 03-03-2020, 10:00 AM   #5
curtis reed
Liked 125 Times in 59 Posts
I use a Longacre digital 0-60lb gauge. I recommend digital to people because you can check the front and back tire pressure with one gauge.
Here are many choices and different price ranges. Best would be a Buxton or Intercomp but they can run from $260-$360.
https://proshop.summitracing.com/sea...rder=Ascending
curtis reed is offline   Reply With Quote
Old 03-03-2020, 12:20 PM   #6
nhramnl
Liked 358 Times in 83 Posts
[QUOTE=curtis reed;609162]I use a Longacre digital 0-60lb gauge. I recommend digital to people because you can check the front and back tire pressure with one gauge.
Some years ago, Gary Stinnett helped me learn about the benefits of a 0-60 gauges, too. As Curtis says, it's really handy to be able to do all four tires, just by moving around the car. I actually don't care very much what the gauge reads, as long as it doesn't vary and I use the same gauge all the time. If the "real", tire pressure, verified by the Intergalactic Bureau of Weights and Measures master gauge is 20#, but my gauge reads 21#, who cares? Kinda like Density Altitude; if your computer says 2300 feet and mine says 2450, I just use 2450 as my baseline DA for the day and don't worry about it. There is no truly "right" value, there is only an accurate, consistent value provided by YOUR equipment.
Old 03-03-2020, 05:15 PM   #7
Paul Merolla
[QUOTE=nhramnl;609176]
I agree completely on both counts...I bought the current one because the range is high enough to read the fronts, but the increments are too close together to be accurate to the 1/2 psi. The digital would solve that.
To your other point about being ok as long as you use the same gauge all the time, that's true except when that gauge is off by 2 psi or when that gauge gives inconsistent readings. (Which mine does)
Old 03-04-2020, 02:29 PM   #8
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
You definitely don't want inconsistent readings, but what difference does it make if the gauge is consistently off by 2 psi? In any case, you need to use the PSI that works best for your car so if you are finding that PSI on your gauge, the accuracy of the number is somewhat irrelevant.
I might feel differently if I raced Top Sportsman, but I think the importance of crazy precise tire pressures is very much overblown. I do use a large-face 0-15 PSI gauge for my dragster, but it's the cheapest one I could find.
S/ST 51
S/C 53
Old 03-04-2020, 05:32 PM   #9
Paul Merolla
You also might feel differently if you raced a stick car on 9" tires!
Old 03-04-2020, 08:20 PM   #10
Doug Walker
Doug Walker's Avatar
Intercomp makes one with a range of 0 - 100 psi. Carry it in my pickup truck. Best one I could find for truck and trailer tires.
