Liked 90 Times in 52 Posts
does anybody have a contact for the old Nelson Specialties people who did modifications on Chevrolet V6 distributors used in the Grand National stock car series years ago . Engine shop has a tagged MSD # 8596 distributor that needs correct cap / rotor that Nelson Spec. put on .
Liked 334 Times in 181 Posts
google their website nelson specialties.com not sure if its current but has contact info etc.---FED 387
Thanks FED for reply .. I got ahold of Joe Pando @ MSD and he found that distributor has been gone since 2006. But he did find the original MSD part numbers for the cap / rotor used on that unit while in production . I mite also look up other oem ignition suppliers who had that odd fire V6 replacement ignition parts
#4 | |
Liked 92 Times in 36 Posts
Ok Drake .. FYI . I.ve called Nelson phone # few times & just keeps ringing & sent emails days ago but never replies
Liked 308 Times in 103 Posts
What do you need to know? You need cap and rotor? I have quite a bit of V-6 experience, I may be able to help you.
If reluctor/pickup is evenly spaced the cap will be evenly spaced on wires. If they are staggered then cap will have wire spaced accordingly.. you can check phasing if not sure... line reluctor/pickup up at each 6 spots and check rotor/cap phasing.. |
Mike .. I did get a new answer & photo from Joe Pando yesterday showing / explaining the not equal spacing of the reluctor & how to properly phase when installing in engine . But still not sure what rotor Nelson Spec. put on their modified 8596 distributor . Joe Pando gave me common in stock rotor MSD put on from factory years ago but not sure if the 8467 MSD rotor is correct for the unequal spaced reluctor since distributor came with the engine to rebuild with no rotor
#8 | |
Hello Drake . do me favor then pls if your can contact Nelson shop when you get moment ask if there was any special part number rotor they used on the modified 8596 msd distributors since the unit came in shop without any rotor and suspicious the one msd Joe pando claimed came from factory looks wrong in pictures we found . thank you for all previous replys
#10 | |
