Old 03-23-2020, 05:44 PM   #1
Mike Jones
Liked 684 Times in 289 Posts
Default SBC 2 Piece Timing Cover
55-86 Small Bock. What brands do you like?
Thank you, Mike
Old 03-23-2020, 06:37 PM   #2
Alan Nyhus
Liked 799 Times in 236 Posts
Default Re: SBC 2 Piece Timing Cover
Mike, I use the cheapy Pro Comp/Speedmaster aluminum one. I did substitute button head screws for the supplied Allen head cap screws as the button heads better fill the recess for the hole. Also, I cut off the front oil pan sealing lip and used the steel ring from a two piece cover to seal the front of the pan. The aluminum cover just seals flat to that.
Just got off the dyno....takes maybe 10 minutes at most to change cam timing, including a couple sips of coffee. Siliconed the lower bolt hole closed (behind the damper) to make things easier. Also made a Lexan cover for it for some other things we were interested in looking at . Here's a couple pics:
"That'll never work....."
Old 03-23-2020, 07:14 PM   #3
rod butcher
Liked 132 Times in 27 Posts
Thank you, Mike
Cloyes it what I used on both motors
Rod
rod butcher is offline   Reply With Quote
Old 03-23-2020, 07:37 PM   #4
Jeff Stout
Liked 704 Times in 281 Posts
Mike, I use the cheapy Pro Comp/Speedmaster aluminum one. I did substitute button head screws for the supplied Alled head cap screws as the button heads better fill the recess for the hole. Also, I cut off the front oil pan sealing lip and used the steel ring from a two piece cover to seal the front of the pan. The aluminum cover just seals flat to that.
I like the see thru cover
Old 03-24-2020, 06:39 PM   #5
SDT1DYI
Liked 453 Times in 146 Posts
Three piece Comp cover along with their adjustable adv/ retard cam gear. Way easier to adjust. Still need to verify using a degree wheel where the lobe centerline is and where it needs to move to, to achieve the desired cam position.
Steve Teeter Stk M/SA 6380/6283
SDT1DYI is offline   Reply With Quote
Old 03-25-2020, 08:18 PM   #6
Mike Jones
Thank you for the replies.
I chose Cloyes hex adjust and their cover.
MJ
