Old 03-22-2020, 08:17 PM   #31
Gmirza
Liked 253 Times in 95 Posts
Default Re: Calvert split mono leaf springs?
Originally Posted by carbuilder View Post
From my 40 plus years of preparing many record holding leaf sprung cars, A spring is a spring,all it does is hold up the car,,,wanna change ride height ? a simple and very cheap easy way is re arc spring,,,why buy and buy when you dont have to??? As far as the spring rate,,,,take a twenty foot long piece of tubing, and support at each end with a jack stand,,,now push down in the middle you will have plenty of spring to it,,,,now cut it and half and do the same thing,,,you will not have the spring anymore because of its length,,,,now when you split a mono leaf,,,you do EXACTLY the same thing. Leaf spring cars with a traction device love the soft spring,,,,shock adjustments respond better and so do tire pressure changes.As far as advantages,,,, I see none,,,only disadvantages
If spending money that is not needed makes one happy,,,go ahead and buy the expensive stuff if that makes life easier,,,, but I can tell you from experience its not needed.
As I said earlier,Keener doesnt use them,and he pretty much can buy what he wants,,,but he has a STOCK spring for a reason,,,and his cars are as fast as they get he has those for a reason
I’m not looking for an argument here, but I disagree with some of your theory. I agree if you take a 20’ long “spring” and cut it in half it will be much stiffer. But the Calvert spring , even though it’s two pieces, it remains the same length. The distance between the load bearing points of the spring remain the same, that is not cut in half. The affect is completely different. With a two piece spring you can have different spring rates or arc ahead of the axle and behind it. So you can keep the front soft so it will work better with the traction device as you stated. Then ride height can be adjusted with the rear spring segment.
Adjustability is one of the advantages of the caltrac springs.
George Mirza
D/SA 1236
‘71 Duster 340
Gmirza is offline   Reply With Quote
Old 03-23-2020, 07:45 PM   #32
carbuilder
Liked 19 Times in 5 Posts
Well I guess someone should inform Keener, Merc and Steve Ficcachi they have the wrong set up, the original question was pros and cons,,,take a split mono and a stock mono,,,and check the pounds per inch,,then get back to me,,,,,
carbuilder is offline   Reply With Quote
Old 03-25-2020, 10:38 AM   #33
340Cuda
Liked 805 Times in 341 Posts
Different is just that different, folks have been equally successful with very different combinations.
Old 03-25-2020, 11:20 AM   #34
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Herb McCandless would be a great source of information on leaf spring technology.
Also, remember the Chrysler Leaf Link used on Ray Whinery's Dart?
I have to admit I am super curious (car is in my garage awaiting a slot for EFI conversion) how its going to work especially compared to the dakota....seemed to work plenty well for Terry Dye when he was running ss/ja....
The dakota uses the old superstock springs and calvert bars.
The debate over launcher springs with calvert bars versus the calvert mono leafs with calvert bars might be a interesting one. The green challenger with a stick is a little indifferent re the mono leafs. Maybe its more of a plus for an auto.
Eric
Eric Merryfield 1883 STK
Old 03-25-2020, 12:30 PM   #35
Pete Lanciers
Pete Lanciers's Avatar
Liked 627 Times in 156 Posts
Eric
Eric,
I seriously doubt anyone who's observed your Dakota's launch would suggest there's much room for marked improvement, LOL!
My E/SA Duster consistently 60fts 1.38-1.39 with Greg's Tri-City Competition Launchers no bars, no snubber, old 5 way Rancho's...
Pete Lanciers
PAL Automotive Racing
Stock 7801
Pete Lanciers is offline   Reply With Quote
Old 03-25-2020, 02:13 PM   #36
Eric Merryfield
Originally Posted by Pete Lanciers View Post
Eric,
Yea it leaves well, I miswrote, it too has Greg's Tri-City Launchers, the calvert bars help keep it down!
Eric
Old 03-25-2020, 05:07 PM   #37
Frank Castros
Liked 2,747 Times in 970 Posts
Eric,
Which springs produced better 60' performance?
Old 03-25-2020, 10:15 PM   #38
GTX JOHN
Gregg's Launchers and John's Mono leafs both work great!
On our 2400LB. Bracket car (Hot Rod Project Feather Duster) we even run Calvert Mono leafs with
No bars....Works great with several track championship!
John Irving
741 Stock
741 Super Stock
Old 04-01-2020, 10:00 AM   #39
Frank Castros
Pete Lanciers,
Please check your PM.
Old 04-03-2020, 10:07 PM   #40
Pete Lanciers
Pete Lanciers,
Frank been trying to respond call me six won 9 two zero o ate 0 five two...
Pete Lanciers
Stock 7801
