Liked 227 Times in 74 Posts
Have Pictures i can text PM with ph#
Ford 8.8 ring & pinion 4.30 gears M4209-G430M used only a few passes on the 1/4 mile $125 Comp rockers 1235-16 ford 5.0 stock style rockers 1.6 ratio $80 NEW C4 Small Block Ford Chromoly SFI Flexplate 157 Tooth 28 oz SBF External and 50oz $30 each Foxbody mustang Upper control arms for 8.8 with sperical bearings on both ends adjustable $225 Hotchkis performance Upper control arms foxbody mustang $75 Fuel rails mustang 5.0 $50 Pinion yoke 8.8 ford Stange part# U1630 New $45 2 set of Valve covers small block ford 302 or 5.0 These are tall enough to fit roller rockers under them and short enough to fit under stock mustang EFI manifold These are stamped steel very light $20 each small block ford roller lifters Sherman short travel $100 Air cleaner stock mustang box K&N part# 33-2015 $25 Comp 4711-16 spring seat $40 new Weiand Team G, BBC intake manifold, part# 7523, oval port, holley 4150, carb flange Very clean, excellent shape, no nicks or dings in machine surfaces $250 Dart, BBC intake manifold, rectangular port, holley 4150, carb flange Very clean, excellent shape, no nicks or dings in machine surfaces $250 Autometer tach Pro-comp2 ultra-lite $150 Magnetic collar for ford 9" NEW, ID 2.187, 2 magnets $50 HVC Msd coil part# 8251 $80 MSD pro power coil still good I just change them every year $20 2 large battery boxes new $15 for the pair Battery switch cole hersee part# 75904? 4 pole for altenator $15 After market seat hi back $50 2 large battery boxes new $15 for the pair QA1 coil over springs 12" 100/200 progressive springs one is new the other slightly used $50 for the pair "Flowmaster scavenger collectors, part# C218250350 NEW still in box $125 2 1/8” primary 2 1/2” secondary 3 ½” Final outlet"
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
Do you still have those flowmaster collectors.
If so could you text me a photo. Am interested in them. 3209806763. |
Yep pictures are on there. These are new never been used
PM sent
