Liked 165 Times in 59 Posts
i am putting together a 904 ,i have had reverse pattern valve body and didn't like the high rpm at the end of the track and what seamed minutes for rpm to come down,i am looking at clean neutral valve bodys ,,turbo action makes a full manual forward pattern with a clean neutral , or do i look for a reverse valve body with two neutrals
this application is for a stocker so no trans brake thoughts? gmonde |
Liked 2,490 Times in 700 Posts
Pro Trans x2
It is what we use..................PERIOD! Meaning we use exclusively Pro Trans the last 20 years ( Not that it has several neutrals)
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 04-19-2020 at 11:22 PM. |
Liked 314 Times in 177 Posts
Reverse valve body with two neutrals.
#5 | |
Liked 503 Times in 131 Posts
You are going to also need a PPP shifter, the turbo action shifter can work, but its super easy to go 1-3, and then your screwed(happened too many times for me in the truck so since its a superstocker, I complaining all the way, went the ACD airshifter route... You might be able to machine up some plates for the Turbo action shifter that would keep it from going 1-3. I love the classic look and feel of the Turbo Action Shifter. ..still miss doing the shifting while way up there, does give me time to look around, count fans, see if the photographer got a good shot, keep steering wheel straight, and it shifts very consistently.....still feels wrong. Kind of boring. There may be another shifter out there now, my experience is 10 years old now, since we put the 904 and PPP in the dragpak. Now if you really want to excite people, figure out how to use that Long shifter with an auto.......I'd buy in a heartbeat, nothing like banging that shifter! Eric
Eric Merryfield 1883 STK |
Liked 695 Times in 206 Posts
I purchased the PPP shifter. Hope to get it running soon.
Liked 3,228 Times in 982 Posts
Eric is right about Rick Allison’s valve body, it’s equally good. Like the Smiths, Rick has been covered up and think Rick has even helped the Smiths some in their transition to Waco but perhaps he’s got one on the shelf. I like the PPP but absolutely love the Turbo Action. Terry Earwood told me Paul was working on a clean neutral shifter so recommend you call Paul and see where he’s at with that.
Whatever you do don’t buy the PPP copycat shifter, Brad (PPP) is super helpful and it burns me people pull that crap.
Jim Carter 2340 Super Stock 2340 SST/2340 Stock Set another place at the table Last edited by jmcarter; 04-07-2020 at 02:01 PM. |
thanks guys !! i called robert and rick over @ A&A and has the set up i need plus the parts i need for my rebuild ,, i like the ppp shifter as well ,,
gmonde |
Liked 10,895 Times in 2,255 Posts
You can change the gate on the TurboAction shifter and it works very well with a clean neutral.
Tha new car has a PPP shifter |
#10 | |
Liked 23 Times in 13 Posts
Frank Bialas 1570 STK |
