Old 04-17-2020, 01:44 PM   #1
MR DERBY CITY
Liked 8,108 Times in 1,531 Posts
Default Sbc Stocker / assorted parts
I have 2 283 Stocker cams ,great for a jr. stock build....283 Stocker grind ,256 duration. ID numbers are 108.g9bc.RL 431-88.....the other cam ID numbers CIC 431-F ,my notes indicate this a Cal Method design ground by General Kinetics.. 50 dollars each...THE 2 Cams are SOLD !! .283 plus .030 tapered ring installer to ease installation of putting pistons in block ..like new 25 dollars...Rimac valve spring tester 0 to 250 lbs...very accurate..200 dollars....
Hooker mild steel merge collectors 13/4 diameter,14 inches long, 2 7/8 collector...50 dollars. RING INSTALLER !SPRING TESTER AND COLLECTORS ARE SOLD????........factory exhaust manifolds off my 70 Chevelle 350 ci that I drove in high school. ....100 dollars...Thanks for looking MJ...502-49nine-014 zero......
Search this Thread:
Advanced Search
