Old 04-06-2020, 06:56 PM   #1
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default 904 clean neutral valve body
i am putting together a 904 ,i have had reverse pattern valve body and didn't like the high rpm at the end of the track and what seamed minutes for rpm to come down,i am looking at clean neutral valve bodys ,,turbo action makes a full manual forward pattern with a clean neutral , or do i look for a reverse valve body with two neutrals
this application is for a stocker so no trans brake
thoughts?
gmonde
Old 04-06-2020, 08:15 PM   #2
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
Default Re: 904 clean neutral valve body
Pro Trans makes one. PR123N. Saves your motor! Dyno
Old 04-07-2020, 02:50 AM   #3
GTX JOHN
Pro Trans x2
It is what we use..................PERIOD!
Meaning we use exclusively Pro Trans the last
20 years ( Not that it has several neutrals)
John Irving
741 Stock
741 Super Stock
Old 04-07-2020, 08:36 AM   #4
Hacksaw
Liked 312 Times in 175 Posts
Reverse valve body with two neutrals.
Old 04-07-2020, 09:33 AM   #5
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Smile Re: 904 clean neutral valve body
thoughts?
gmonde
Use either the Pro-trans version or the A&A version I have both. Both flawless.
You are going to also need a PPP shifter, the turbo action shifter can work, but its super easy to go 1-3, and then your screwed(happened too many times for me in the truck so since its a superstocker, I complaining all the way, went the ACD airshifter route...
You might be able to machine up some plates for the Turbo action shifter that would keep it from going 1-3. I love the classic look and feel of the Turbo Action Shifter.
..still miss doing the shifting while way up there, does give me time to look around, count fans, see if the photographer got a good shot, keep steering wheel straight, and it shifts very consistently.....still feels wrong. Kind of boring.
There may be another shifter out there now, my experience is 10 years old now, since we put the 904 and PPP in the dragpak.
Now if you really want to excite people, figure out how to use that Long shifter with an auto.......I'd buy in a heartbeat, nothing like banging that shifter!
Eric
Eric Merryfield 1883 STK
Old 04-07-2020, 10:51 AM   #6
Dyno
Dyno's Avatar
I purchased the PPP shifter. Hope to get it running soon.
Old 04-07-2020, 12:00 PM   #7
jmcarter
jmcarter's Avatar
Liked 3,204 Times in 977 Posts
Eric is right about Rick Allison’s valve body, it’s equally good. Like the Smiths, Rick has been covered up and think Rick has even helped the Smiths some in their transition to Waco but perhaps he’s got one on the shelf. I like the PPP but absolutely love the Turbo Action. Terry Earwood told me Paul was working on a clean neutral shifter so recommend you call Paul and see where he’s at with that.
Whatever you do don’t buy the PPP copycat shifter, Brad (PPP) is super helpful and it burns me people pull that crap.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 04-07-2020, 07:19 PM   #8
gmonde
gmonde's Avatar
thanks guys !! i called robert and rick over @ A&A and has the set up i need plus the parts i need for my rebuild ,, i like the ppp shifter as well ,,
gmonde
Old 04-08-2020, 07:45 AM   #9
Liked 10,804 Times in 2,245 Posts
You can change the gate on the TurboAction shifter and it works very well with a clean neutral.
Tha new car has a PPP shifter
Old 04-18-2020, 02:27 PM   #10
Frank Bialas
Frank Bialas's Avatar
Liked 23 Times in 13 Posts
thoughts?
gmonde
I thought only one neutral allowed in stock elm.
Frank Bialas 1570 STK
Frank Bialas is offline   Reply With Quote
