Liked 20 Times in 15 Posts
I am considering stock class racing my 56 Chevy, [again] after many years. does the rule book still say you have to run a corporate rear axle? I do ,not want a 12 bolt.
can I use a '55-'64 style center with different bearing ends and race axles? also can the tubes be shortened[just a little]? thanks Rod min AZ |
#2 | |
Liked 231 Times in 107 Posts
Liked 997 Times in 201 Posts
Rod, you could use a 57 -64 Pontiac/ Olds rearend housing if you wanted to retain the stock look. It is not legal to make the stock rearend narrower plus the tires will be up against the springs if you do. A cheaper alternative is finding a 8.5 out of a Camaro or Firebird. Just as strong as a 12 bolt, but not as many ratio options.
Liked 5,146 Times in 1,964 Posts
Better reconsider the 12 bolt ,with Pro gears, if it's going to be a stick car.
Pontiac/ Olds not legal in Stock
Liked 272 Times in 108 Posts
Liked 8 Times in 3 Posts
The Olds/Pontiac rear is not acceptable for a Stocker trifive......I asked.
Liked 974 Times in 310 Posts
Why?
Liked 172 Times in 81 Posts
REAR END Original rear end may be replaced with another from the same automobile manufacturer; truck rear end prohibited. Aluminum center section permitted only on vehicles that were originally equipped with same. Distance between backing plates may not be changed. Any gear ratio that fits third-member case or housing permitted. Limited-slip or ratchet-type rear ends permitted.
So a COPO comes with a 9" Ford so I guess a 9" Ford is now legal? Jim Mantle V/SA 6632 |
#9 | |
Liked 101 Times in 52 Posts
What Jim said. Tech Director said, must be Chevrolet.
And a big no on the 9". Asked about that one last year. Last edited by XSTOCKER; 04-27-2020 at 02:03 PM. |
