#41 |
Liked 734 Times in 385 Posts
#42 |
Liked 799 Times in 236 Posts
Billy, many years ago I parted out one of these cars for the engine. I didn't want to let the shell go with the Spicer rear in it but a hard hit on the rt. rear had tweaked the caliper and rotor and I figured the axle tube was wonky. In retrospect, I should have pulled the rear end.
"That'll never work....." Last edited by Alan Nyhus; 05-04-2020 at 07:40 AM. |
#43 | |
When I made the wagon a Jr Stocker, I ran the Pontiac rear, not one Tech guy ever noticed. When I went to the sedan the next year, I kept the Chevy rear end. Not nearly as nervous if a Tech guy looked under it. Pontiac rear could be no faster, just more heavier, and less starting line breakage. They looked much alike from the back, Pontiac was a little larger. For a whole season, nobody noticed.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 05-03-2020 at 12:33 PM. |
#44 |
Liked 320 Times in 102 Posts
You guys got me thinking.....
I have a state of the art Chevy Drop Out Center Section with maybe a 5.38 gear Henry's Axles, MOPAR spline with heat treated Stahl-Moroso side gears, Steel carrier bearing cap, alternate Posi Plate stack and the back of the housing has a tension bolt to pre-load the cap. State of the art in 1965...
#45 |
Are aftermarket 12 Chevy diffs legal in stock and super stock?
The 68/69 Cutlass and 442 built in Canada had a 12 Chevy diff. Aftermarket diff link https://www.markwilliams.com/gm-12-bolt-housings.html Last edited by Bernhard; 05-10-2020 at 12:52 PM. Reason: Link added |
