Old 05-11-2020, 11:08 PM   #11
GTX JOHN
Default Re: new enclosed trailer [maybe aluminum] feedback
My son has built both aluminum frame and steel square tube frame trailers.....
Really very little different in weight.
Aluminum is much more fragile in rough service and rugged terrain!
Also be sure to get a .040 exterior wall not .020/.030 or in a year it
will have more wrinkles than my B*tt does!
Square tubing on walls not angles helps and makes it easier to mount stuff.
He can get a steel 20' under 3000 lbs depending on options and interior
and prices start around $6,500. for a 20 and $7,500 for a 24.
He has OVER 50 Trailers in Stock in Different Configurations.
Custom Build time is currently Two Weeks!
There are cheaper ones in Georgia:
BUT as John Arbuckle said "You get what you pay for"
Jon Irving (aka JR)
(702) 917 -6471 is his work phone
(We are on AZ/NV Border)
He can give you references from several of the better know folks
on this site who have bought their trailer ( Or Trailers ) from him!
BTW: He uses AMERICAN MADE Dexter Axles/Springs/Brakes/Suspension
Components etc.that cost him TWICE what the Chinese Garbage costs!
Most Builders DO NOT!
John Irving
741 Stock
741 Super Stock
Old 05-12-2020, 07:16 AM   #12
RKelliher
Liked 188 Times in 62 Posts
Three years ago I bought a Anvil 24 ft. enclosed trailer.I was towing it with a 1988 Holiday Rambler class A. Towed with no problems, I now tow with my 2018 silverado 1500 with 5.3 and tow package. Tows very well. Truck rated for 10k lbs. with equilizer bars. The trailer is made in Georgia ,very good price.Has 6 in. box frame witch is much better than i-beam or channel. Don't recommend v-nose, too much wasted space. I recommend 4ft. side door. I carry 81 camaro ,3400 lbs tool box bench ,etc. also this year I carry a golf cart inside. Still tows very well. check them out.
RKelliher is offline   Reply With Quote
Old 05-12-2020, 10:15 AM   #13
340Cuda
Liked 805 Times in 341 Posts
Originally Posted by Glenn Briglio View Post
Check out Intech trailers
The nicest trailers I have seen lately.
Old 05-12-2020, 12:22 PM   #14
Glenn Briglio
Glenn Briglio's Avatar
Liked 978 Times in 313 Posts
It's not a goldrush but it doesn't have the goldrush price either.It's very nicely constructed.
Old 05-12-2020, 01:03 PM   #15
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
I would call Randy Cape at Flying A Motorsports. (800-222-4004) I drove down there (1300 mile round trip) a week ago to talk to him and see the different types of trailers they stock and what to look for in the different price ranges. He has a wealth of knowledge after designing, building and selling trailers for over 30 years. And not only that, he is a real nice guy and no high pressure to buy. Well worth the call. Dyno.
Old 05-12-2020, 01:53 PM   #16
jmcarter
jmcarter's Avatar
Liked 3,250 Times in 989 Posts
While in the Elkhart area getting some MH warranty items taken care of I toured both the InTech and ATC facilities (tour the Newmar plant also in Nappanee if you have time). Both are top notch with completely different manufacturing approaches but I’d give the nod to InTech, their workforce is largely Amish and the craftsmanship is simply better. Beyond that I’d shop locally and support racers when possible, for instance in the west I’d call Jon Irving. In the Northeast I’d look at Chris Howe’s pick, in the Southeast I’d go elsewhere unless price is the #1 item on your list. In the Midwest, I’d second Dyno’s recommendations of talking to Randy at Flying A, they have something for every budget.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 05-12-2020, 06:53 PM   #17
Dragsinger
Liked 99 Times in 60 Posts
Thanks to all for the info. I will follow up with these listed builders.
Larry Woodfin 471W
Old 05-12-2020, 07:53 PM   #18
Ed Wright
Ed Wright's Avatar
I bought a 24’ ATC all aluminum trailer a few years ago. I would recommend ATC. I had a steel open trailer before, and the 24’ ATC is easier for my 2500 Suburban to tow. It does not feel any heavier than my old trailer, that was 2 ramps, not a steel flat bed trailer. My ATC came with electric brakes on one axle, I added brakes to the other axle. I did go to 16” wheels, with Michelin LT tires. Trailer tires, I learned, are speed rated to 55 MPH? Oklahoma Turnpikes’ speed limits are 75MPH. Trailer tires don’t like that. Don’t live well at that speed. LT tires are rated at 95 or 98?
Those 16” 6 ply LT tires (same as my ‘99 2500 Suburban uses, also are more stable. I tow the speed limits. I use 60psi in my trailer tires, same as my Suburban. Very stable.
My ATC came with nice aluminum cabinets & work bench. I would buy an ATC again.
I towed it with Jeanie’s 1500 Tahoe at first. Zero issues.
Ed Wright 4156 SS/JA
Old 05-13-2020, 01:37 PM   #19
Kenney Kelley
Liked 72 Times in 36 Posts
One thing to think about with a 1/2 Ton truck is all the weight of the truck and the tongue weight of the trailer is supported by only the size of the axle witch might be only 1" to 1 1/2" at the bearing that's a lot of stress right at that point But with a 3/4 -1 ton truck the weight is supported by the rear end housing and not the axle. Just something to think about. Plus along with the weight of the car you will probably add the weight of a generator, air compressor, tool boxes, Battery for a winch and lights, tent with chairs, fuel cans, floor jack, Golf Cart or Pit Bike, Coolers with Ice. That's just a few items you might need before heading to the track. Kenney Kelley
Kenney Kelley is offline   Reply With Quote
Old 05-13-2020, 04:03 PM   #20
63corvette
Liked 362 Times in 105 Posts
My experience over the years and owning both steel and aluminum trailers is aluminum is lighter to pull and if you buy quality aluminum you can not go wrong there.
There are steel trailers built with box steel frames which are strong and light.
Lightweight for towing is your best bet whatever you pull it with as we all load them down with all the things we carry. I carry much more than I should and probably need to.
I have owned Goldrush and they are expensive and other manufacturers are just as good if they use aircraft type aluminum framework.
The aircraft quality aluminum is the key to an aluminum trailer being trouble free and lasting. Some manufacturers cut costs by using cheaper aluminum for the frames.
I pulled a Goldrush 28 ft. box trailer which was equipped with most all the extras available with a HD 1/2 ton PU with the trailer package without any issues unless it was into a big headwind. With the big head wind I could not run over 60 to 65 MPH.
I now have a Rengegade stacker with a aluminum frame and have been fairly pleased with it. My issues with it were with some of the items Renegade bolted onto their box.
In any case buy quality as others have said you get what you pay for.
Good Luck in Your Search.
Rick Cates
Canyon, TX
63corvette is offline   Reply With Quote
