Old 05-18-2020, 10:12 AM   #11
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default Re: cc'ing cylinder heads
Is it a no-no to use tap water?
Ron Gusack is offline   Reply With Quote
Old 05-18-2020, 10:53 AM   #12
Dave Gantz
Liked 251 Times in 125 Posts
Water has a lot of surface tension that would make it hard to make it flow. Surface tension can be broken with a few drops of dish soap, but I never tried it to cc.
Old 05-18-2020, 12:11 PM   #13
Myron Piatek
Liked 138 Times in 51 Posts
LOCOMOTION Racing
Old 05-19-2020, 05:49 PM   #14
Steve Polhill
Steve Polhill's Avatar
Liked 262 Times in 74 Posts
Originally Posted by jmantle View Post
I normally use isopropyl alcohol for checking chamber and port volumes, can't seem to buy any right now, what else works?
Jim Mantle V/SA 6632
Windshirld waster fluid. It's cheap, easy to find, and a gallon will last you for ever. The winter -40 type the summer stuff is more of a soap and can foam up.
Steve Polhill
3520 STOCK, COMP
Steve Polhill is offline   Reply With Quote
Old 05-20-2020, 03:44 AM   #15
4406mopar
Liked 120 Times in 53 Posts
Originally Posted by silversedan View Post
I use marvel mistery oil , cause it's red an easy to see.
How about ATF?
4406mopar is offline   Reply With Quote
Old 05-20-2020, 11:04 AM   #16
John Dinkel
Liked 263 Times in 68 Posts
Too thick
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
