Liked 3 Times in 2 Posts
If I read the stock car classification correctly, this should fit O - P/SA. however the question I have is under the classification is reads ESI (Engine specs Incomplete, but it gives a HP rating of 210 and a weight of 3345 for the rag top. Is this a legal combination to race with or is it not allowed due to the ESI designation?
NHRA: Comp 2200 - S/C 2201 NMRA 2012 Outlaw 10.5 #10 |
You would need to contact the Tech Dept. and get someone to put the engine specs in the guide. Until that happens, the combo isn't approved.
Umm, I was corrected about the way to get your combo put in the guide. You would have to contact someone from FFFord and ask them to submit the specs to the Tech Dept..
Liked 776 Times in 199 Posts
Yes, you have to contact somebody at Ford that will send in the info to the tech dept. When I got the 2003 Mustang stuff put in the guide, Jesse Kershaw was the contact at Ford racing and he was a great help. I would try to contact Ford racing.
Bret Velde 2003 FS/?? |
Liked 755 Times in 213 Posts
I'm a little lost here.
I need more details regarding that post. Since this car is in the official NHRA Stock Car Classification Guide, rules says: "Only those cars listed in the guide are "eligible" for competition". This car is in the guide, so it become OK. There nothing in the rulebook regarding ESI. (May be I mist something here?) Now if I go to the Blueprinting paragraph: Stock factory OEM components (unless otherwise specified)must be retained and remain unaltered. This tell me that when ESI are not available from Ford or NHRA, you must keep OEM components. Thank you in advance for your precious help, Charles Stewart Last edited by Charles Stewart; 05-20-2020 at 04:42 PM. |
Liked 783 Times in 195 Posts
There are lots of combinations in the Class Guide that are like that. If there are no engine specs, then you cannot race it in Stock or normal SS classes. You can use it to build a SS/GT car or an SS/Modified car. Usually that is why the combination is there.
Thanks Mr. Southerland,
I was aware of that (*) regarding SS/GT and SS modified. Your answer also confirmed me, that NHRA Rulebook isn't complete in that regard. An add-up, like you said, (If there are no engine specs, then you cannot race it in Stock) should follow the text: "Only those cars listed in the guide are "eligible" for competition". (*) By the way, your website Classracerinfo is a fantastic tool. Keep on Sir, Charles Stewart |
Thank you for the appreciative remarks!
There is a statement in the rule book that can be taken as an explanation, though it does not specifically explain the ESI issue. "The power-to-weight factor (as found in the Official NHRA Stock Car Classification Guide) determines the natural class for all cars." If there is no power-to-weight factor, there is no class implied.
Thank you, that is what I was afraid of. Will just keep looking for now.
Liked 84 Times in 42 Posts
I was thinking about this combination too a while back. When I was at the PRI show I intended to talk to whoever is in charge of the drag racing program now but I never had the chance to. Does anyone know who it is now and maybe his/ or her email address?
It would be a great starter car for someone just getting started.
Bob Tilton 568 FS/H |
