Old 06-03-2020, 12:25 PM   #11
Kevin Panzino
Kevin Panzino's Avatar
Liked 778 Times in 142 Posts
Default Re: Battery tender that actually lasts..
Great. Thanks for the info gents!
Old 06-07-2020, 07:55 AM   #12
SGSST109E
Liked 126 Times in 61 Posts
Use the Battery Tender Brand. I have three and have had them for 1o to 15 years
SGSST109E is offline   Reply With Quote
Old 06-07-2020, 12:09 PM   #13
Floyd Staggs
Floyd Staggs's Avatar
Liked 229 Times in 99 Posts
I have 3 of the Battery Tender Jr's that are on all the time. One on the race truck, one on the UTV and one on the pit bike. Makes the batteries last a lot longer when you keep them charged up.
Floyd Staggs 787 SST
Old 06-07-2020, 01:24 PM   #14
Monte Howard
Monte Howard's Avatar
Liked 71 Times in 23 Posts
Auto meter makes the best one that I have found.
Monte Howard 3209 STK, 3208 SS
Monte Howard is offline   Reply With Quote
Old 06-07-2020, 03:05 PM   #15
Chuck Gallagher
Liked 134 Times in 28 Posts
Kevin;
I agree with Monte.
I've had two Autometer Battery Extenders Model 9202 since they first made them back in the 80's. The first one lasted over 20 years and then they sold me another one cheap which I still use, a lot.
They have an aluminum finned outer shell that does get hot if the battery is heavily depleted but after an over night charge the battery is usually fully charged.
This model 9202 is rated at 1 amp charge with 250 milliamp maintenance rate. A lot of us veterans have these stopped using a regular charger (except at the track) years ago.
Chuck
Chuck Gallagher is offline   Reply With Quote
Old 06-08-2020, 07:35 PM   #16
Ed Wright
Ed Wright's Avatar
Originally Posted by curtis reed View Post
The fact that you said battery tender is funny. The Battery Tender brand has worked great for me for years. Pricing is pretty decent also. Just what has worked for me.
Curtis
I agree. My Battery Tender brand tender is probably ten years old, with no issues at all.
Has anybody modified one for 16 volts? Been kicking that around.
Ed Wright 4156 SS/JA
Old 06-08-2020, 11:21 PM   #17
ss chief
Liked 48 Times in 13 Posts
The one I have has a 12 volt and 16 volt option. I think it is Auto Meter.
ss chief is offline   Reply With Quote
Old 06-09-2020, 09:14 AM   #18
Dale Hulquist
Liked 351 Times in 76 Posts
SS Chief can you post a model # and brand if its not a battery tender for the 12-16 volt version, I would be interested in purchasing one?
Dale Hulquist
4006 Stk
4006 S/Stk
Dale Hulquist is offline   Reply With Quote
Old 06-09-2020, 10:15 AM   #19
FED 387
Liked 335 Times in 182 Posts
attometer makes/made a model 5000 for battery maintaining --multi voltages --also Schumacher used to make a CR-2 (cost about $20-25) for those little kids battery powered cars superseded by a CR-8 --- about a 1.5 amp unit I believe ---might be worth spending the money to see if you can get one to work on a 16 volt battery probably have to change ends for alligator clips or whatever ---for $20 its worth a try --I think you can get them at Walmart or on line---FED 387
Old 06-09-2020, 12:42 PM   #20
ss chief
Auto meter 9202, not sure it is still available.
