Liked 15 Times in 11 Posts
how many sizes down should one go to see a difference (better or worse) on the secondary rods of a q-jet? This is on a small block stocker engine.
Liked 1,943 Times in 584 Posts
What do you have in it now and who built the carb?
Mike Pearson 2485 SS |
Liked 5,129 Times in 1,956 Posts
I'd say 5-6 thou, depending on what's available..
If you're still foot braking, you might see a change with the hanger too. Try to stay in the median alphabet range It your carb won't run that way, there's always the seat of the pants method..Almost lost in this day and age.
#4 | |
thanks john |
Hangers are lettered A-V I think. Each letter down the alphabet will pull the sec. rod out of the jet .005 later.
Starting with say a K, L M will give you room to fine tune in either direction.
Had 57s on a J in it last night, switched to 55s on the same J, no difference. Don't have too many rod sizes, just put 44s on the J for next week. Have an H and I that could go in too.
My car is a super stock car. I never run anything smaller than a .057 rod. In the heat I usually run .066 rods. J or K hanger. That’s what I had in at Atlanta last weekend and it picked up from the .057 that I had in for the first Q pass.
Liked 73 Times in 36 Posts
Easiest thing to do is calculate the square inches of area of the main secondary jet which is fixed (I use 0.135" diam = Area of 0.014313915 sq in) then subtract the area of the secondary metering rod tip so the difference is the functional area of the secondary jet with that metering rod. As an example, the guy that raced his SS in Atlanta said he used a 0.057" and a 0.066" tipped rod so that is a change of area of 30%.....wow. Normally one would want to change only about 5% or so at a time, but that is just a suggestion. Whatever works for you.
Best thing to do is to make a chart or table of whatever your metering rod tip selection is and do the arithmetic. Regards to all that like this kind of stuff. ![]() Otherwise just put your mask on and change the channel to reruns. ![]() HB2 ![]() Dissident |
Liked 1,829 Times in 427 Posts
You want to see a difference ?
Go from a 55. To a thin 34 Rod. It’s basic tuning. Throw a bunch of fuel. See what happens It’s probably too much but then try something in between It’s seat of the pants Tuning it works for me. Hangers. Same thing B hanger is most aggressive. Then D. E. F You won’t know unless you try
james perrone 1290 STK |
Liked 734 Times in 385 Posts
Can someone post up what the weather is when they run a 0.057" rod and when they run a 0.066" rod? Looking to see how far off my math is.
Stan |
