Old 06-13-2020, 12:33 PM   #1
Dave1695
Liked 15 Times in 11 Posts
Default changing q-jet secondary rods
how many sizes down should one go to see a difference (better or worse) on the secondary rods of a q-jet? This is on a small block stocker engine.
Dave1695 is offline   Reply With Quote
Old 06-13-2020, 12:52 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,945 Times in 586 Posts
Default Re: changing q-jet secondary rods
What do you have in it now and who built the carb?
Mike Pearson 2485 SS
Old 06-13-2020, 01:46 PM   #3
I'd say 5-6 thou, depending on what's available..
If you're still foot braking, you might see a change with the hanger too.
Try to stay in the median alphabet range
It your carb won't run that way, there's always the seat of the pants method..Almost lost in this day and age.
Old 06-13-2020, 03:13 PM   #4
Xbody
Xbody's Avatar
Mark,please define median alphabet range
thanks john
Xbody is offline   Reply With Quote
Old 06-13-2020, 04:04 PM   #5
thanks john
Hangers are lettered A-V I think. Each letter down the alphabet will pull the sec. rod out of the jet .005 later.
Starting with say a K, L M will give you room to fine tune in either direction.
Old 06-13-2020, 06:33 PM   #6
Dave1695
Had 57s on a J in it last night, switched to 55s on the same J, no difference. Don't have too many rod sizes, just put 44s on the J for next week. Have an H and I that could go in too.
Old 06-13-2020, 09:32 PM   #7
Mike Pearson
My car is a super stock car. I never run anything smaller than a .057 rod. In the heat I usually run .066 rods. J or K hanger. That’s what I had in at Atlanta last weekend and it picked up from the .057 that I had in for the first Q pass.
Old 06-14-2020, 01:21 AM   #8
Dissident
Liked 73 Times in 36 Posts
Easiest thing to do is calculate the square inches of area of the main secondary jet which is fixed (I use 0.135" diam = Area of 0.014313915 sq in) then subtract the area of the secondary metering rod tip so the difference is the functional area of the secondary jet with that metering rod. As an example, the guy that raced his SS in Atlanta said he used a 0.057" and a 0.066" tipped rod so that is a change of area of 30%.....wow. Normally one would want to change only about 5% or so at a time, but that is just a suggestion. Whatever works for you.
Best thing to do is to make a chart or table of whatever your metering rod tip selection is and do the arithmetic.
Regards to all that like this kind of stuff.
Otherwise just put your mask on and change the channel to reruns.
HB2
Dissident
Dissident is offline   Reply With Quote
Old 06-14-2020, 10:02 AM   #9
James Perrone
Liked 1,842 Times in 429 Posts
You want to see a difference ?
Go from a 55. To a thin 34 Rod.
It’s basic tuning. Throw a bunch of fuel. See what happens
It’s probably too much but then try something in between
It’s seat of the pants Tuning it works for me.
Hangers. Same thing B hanger is most aggressive. Then D. E. F
You won’t know unless you try
james perrone 1290 STK
James Perrone is online now   Reply With Quote
Old 06-14-2020, 12:31 PM   #10
Stan Weiss
Stan Weiss's Avatar
Liked 734 Times in 385 Posts
Can someone post up what the weather is when they run a 0.057" rod and when they run a 0.066" rod? Looking to see how far off my math is.
Stan
