Liked 34 Times in 12 Posts
TH350 low drag aluminum drums with updated ATI aluminum drum and 36 element sprag, TCI pump, TH250 gun drilled output and lightened sun shell, Stef’s pan. New JW bellhousing. Best parts. Fresh from Tim Sloan, less than 20 runs since new. $1800
402 BBC Diamond pistons and pins new/unused 4.191 bore .0415/.043/3mm coated top. Will throw in ring set with 4 dyno pulls. $600 Sold JE 396/350 pistons (6), Crower rods 2.200/.927x2.500 (2 new), new pins. Need 2 pistons to complete $500 290 Heads Up heads, one repaired but would replace or have one excellent spare, with some valves $500 BBC 904 Isky lifters EZ-MAX bearing option excellent condition $400 BBC 904 Isky lifters 376-RHM-904 new $600 BBC Comp 892C 904 lifters good used, one new $250 Misc roller cams std bore $150 Merlin intake, oval port, ported for super stock $400 Sold Early Q-Jet tuning parts- Hangers (33) J-Qty 4, H-Qty 4, N-Qty 2, M-2, I-1, O-1, L-5, K-5, P-6, V-3 Secondary Rods (28 sets) DS-4, DH-3, CH-3, DG-8, DU-5, DG-1, DB-2, CZ-1, CP-1 Jets (5 sets) 77,76,74,73,71 Primary Rods (6 sets) .035, .037, .039, .041, .043, .045 $150 for all- will not separate. Sold Nova weather station in case with altimeter, calculator and sling psychrometer. Calculator works but batteries were dead and will need program from family software. Was the hot lick back in the day $100 Tag handheld unit- works, used up until last year. Bought Race Air. $150 SOLD 82 camaro factory fiberglass hood, one corner needs minor repair $300 Going to Mooresville Friday morning, can deliver. All plus shipping call or text 9 one 9 96185 zero 5 for info and pics. Last edited by bert powell; 06-19-2020 at 04:50 PM. Reason: Sold |
Liked 208 Times in 35 Posts
What low gear ratio ?
Rick Winchester Stk 3277 |
If still for sale , does it have trans brake ?
Thanks Rick.
