Old 06-22-2020, 10:30 AM   #1
ZenzenRacing
Liked 53 Times in 17 Posts
Default Trans Problems!
Second time in 35 passes rolled the sprag for second gear on the T350 in the SS car! Ideas why?
ZenzenRacing is offline   Reply With Quote
Old 06-22-2020, 10:36 AM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Default Re: Trans Problems!
I was told not make 1-2 shift in burnout, so I just started burnout in high, and if reverse pattern was told not shift from high back to neutral while moving....
both were hard on sprag..
Old 06-22-2020, 10:41 AM   #3
ZenzenRacing
Yep, we do the 2nd to high burnout but on the other end we do go high to neutral.
Old 06-22-2020, 11:29 AM   #4
57 Vette
57 Vette's Avatar
Liked 38 Times in 14 Posts
Do Burn out in High Gear only. Make sure to use 36 Element Dog Bone Sprag with harded race.
57 Vette is offline   Reply With Quote
Old 06-22-2020, 11:51 AM   #5
bykr
Liked 167 Times in 81 Posts
I always thought that was funny, engine builders say don't leave it in gear at the end of a run and trans builders say don't shift to neutral
Tim Schmackpfeffer 762 SS
bykr is offline   Reply With Quote
Old 06-22-2020, 12:09 PM   #6
Lee Jordan (3223) A/S
Lee Jordan (3223) A/S's Avatar
Liked 55 Times in 17 Posts
From what I have been told if you shift to neutral after the run the trans wont oil good enough coasting so fast. I dont know for sure but understand that it is hard on the motor slowing down in gear too...
1967 Fairlane A/Stick - 1994 Mustang GT. 1989 Oldsmobile, R/SA - 2016 Z06 Weekend Street Car.
Lee Jordan (3223) A/S is offline   Reply With Quote
Old 06-22-2020, 01:51 PM   #7
Jim Hanig
Liked 99 Times in 49 Posts
It is not good to shift a 350 400 into netural at the line it over speeds the drum, sometime causing it to come apart.
Old 06-22-2020, 03:05 PM   #8
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Some of the aftermarket high gear drums have sprags that do not have end bearings . These are no good , the end bearings keep the inner and outer races concentric . Without the end bearings the sprag dog bones will not engage evenly and will roll over in short order .
Old 06-22-2020, 03:21 PM   #9
Mike Pearson
Mike Pearson's Avatar
Liked 1,944 Times in 585 Posts
one reason I stick with a powerglide. They are virtually indestructible. Not as fast as a good 3 speed. But very consistent and reliable. I know I could pick up a couple of tenths with a good 3 speed like a Coan XLT or a Pro trans.
Mike Pearson 2485 SS
Old 06-22-2020, 07:53 PM   #10
Jim Kaekel
Liked 535 Times in 110 Posts
Another thing. Be sure the trans builder did not remove the accumulator spring. Some do. It will make the shift into second very harsh, which is hard on the intermediate sprag.
Jim Kaekel 3836 STK
