#21 |
Liked 4 Times in 3 Posts
With the Qjet it all depends on the size of Primary and Secondary bleeds.
Too small of a bleeds it will go dead Rich. Too big of Bleeds and you can't get a small enough tip. Last edited by SS734; 06-18-2020 at 06:19 PM. |
#22 | |
Liked 73 Times in 36 Posts
Mr Nyhus and Others that might be interested in some facts from measurements, ![]() 1) Most 750 type QJs flow test to be from a very poor low of 164cfm to an average of 170-175cfm at 20.4"H2O test pressure. ![]() 2) Most 750 type QJs flow test at 660cfm to 675cfm on the secondaries at the same test pressure as above. ![]() 3) Doing some quick math to see how much that is in mass flow of air in lbs/hr at sea level, yields 798 lbs/hr on Primaries and 2622 lbs/hr on Secondaries. 4) Allowing for max power at somewhere near 12.5:1 A/F ratio would yield fuel use on primaries of 63.84lbs/hr (127.68Hp) and 209.76lbs fuel use on secondaries (419.52Hp) supplying a total of 547.2Hp ![]() As you can see, that is 23.33% fuel on primary and 76.67% on the secondary. IF one sees that the primary is supplying the 40% as claimed in the quote, one can only assume the secondaries are not at WOT or something is categorically wrong with the carburetor or the fuel supply system tune. ![]() Hope that helps.....No, I do not have a race car but have supplied assistance to make more than a few more than competitive. ![]() Regards, HB2 ![]() Dissident |
#23 |
Liked 705 Times in 282 Posts
I measured the diameter of butterflys on both sides and it worked out 20% primary 80% secondary. May not be exact science IDK
#24 |
Although that is a good observation, Mr. Stout,
![]() The 800 type QJ have the same throttle plate and blades but flow considerably more on the primaries due to a larger venturi for those carburetors which produces an average of 207cfm to 209cfm. And the bias changes the percentage of fuel used, but that is yet another oddity of the QJ organized leaks. ![]() ![]() Regards to all that like this kind of stuff, HB2 ![]() Dissident |
#25 | |
Liked 734 Times in 385 Posts
Harold, Just a question about the BSFC you used. Is that what a competitive engine will show or did you just choice it for ease of Math? Never seen a dyno sheet from a competitive S or SS engine. Stan |
#26 |
Stan,
Thanx for the question. ![]() In the example I used here, I just used a BSFC of 0.5lb/hp-hr which is a pretty good target for planning. However, it is quite common for BSFCs to be somewhere around 0.45 to 0.47 when everything is complimentary. Stockers have to use OEM manifolds and SS stuff uses other than OEM so they can get a bit more fuel efficient as happens when CR go up as well. I did not get into an analysis of efficiency, simply wanted to point out the fallacy of following the wrong guidelines on how the goofy QJ works in practice. These things are more fun than a box of puppies when tweaking them on the dynamometer. ![]() Regards, HB2 ![]() Dissident |
#27 | |
Liked 799 Times in 236 Posts
Measuring throttle bores or primary/secondary air flow and extrapolating that to fuel flow doesn't take into consideration how a QJet triple venturi primaries meters fuel as compared to the the non-booster secondary side that has a simple discharge tube. On the primary side, even the idle circuit contributes to fuel flow as the primaries open. As quirky as they are, I love 'em. ![]()
"That'll never work....." |
#28 |
Liked 27 Times in 19 Posts
Anybody try different sizes of sec. air bleeds?
#29 |
Yes.
![]() ![]() Regards to All that like this kind of stuff, HB2 ![]() Dissident |
#30 |
Yes. The air bleeds/emulsion tubes are very important. -Al
