Old 07-09-2020, 12:01 PM   #11
Default Re: Advantage radials to Bias Plys
Don't waste your time and money on bias plys
You're dealing with a new combo that may not be the best for U/SA.
Don't leave any ET on the table.
There are plenty of used radials out there for sale from the higher class cars , that will work very well for you.
Old 07-09-2020, 12:10 PM   #12
Jim Caughlin
Liked 806 Times in 246 Posts
We had them on the truck testing and radials were quicker and faster, but only hooked 20% of the time. Maybe with some work it could be a player
Same here on the stick application, went a little faster but blew the tires off about 1 run in 4. Can't win any races that way.
Jim Caughlin
SS 6019
Jim Caughlin is offline   Reply With Quote
Old 07-09-2020, 01:12 PM   #13
Jeff Stout
Liked 708 Times in 285 Posts
This is what I did. A used set if bias and used set of radials. Bias finally cracked to much. Radials have plenty of life in them but it looks like Az sun exploded one of the tires on car last week. Guess I should have covered them up.
Old 07-09-2020, 05:45 PM   #14
Liked 11,010 Times in 2,263 Posts
That was the V/S combo in the truck. If you have the power to use them Goodyear 1909 is a good stick tire.
Old 07-09-2020, 08:40 PM   #15
Rose Racing
Rose Racing's Avatar
Liked 227 Times in 74 Posts
Well its not about the cost of the tires its about the cost of wheels Mark... I have 14 by 7 wheels currently and You can find a M/T Slick or Hoosier Slick that would fit but with a different set of wheels I would run the Goodyear D4892... Ive always pretty much been a Goodyear guy ive always ran Goodyears on my No Box bracket car but I mean wheels are very expensive but I did find some Wheel Vintiques wheels that might work.
Rose Racing is offline   Reply With Quote
Old 07-10-2020, 12:47 AM   #16
15" x 8" on a 4, 1/2 bp shouldn't be too hard to find on C/L or swap meet.
Old 07-10-2020, 09:35 AM   #17
Mike Pearson
Mike Pearson's Avatar
Liked 1,985 Times in 598 Posts
It s been quite a few years ago since I went from Bias to radial. When I made the switch I made two run with the radials and took them off. They were ill handling. I put bias back on and ran it that way for several more races. I was forced to put the radials back on the car one day due to getting a flat. I put the same air pressure in the radial as in the bias and the next pass was 0.13 faster than with the bias tires and handled perfectly. Both times I tested this the result was the same . Since then I run the radials all of the time and run them about 13 psi.
This is a super stock car and I run the Hoosier 13.5 x 31.5 radial
Mike Pearson 2485 SS
