Old 07-09-2020, 04:28 PM   #1
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default retarding timing in high gear on a stocker
has anyone seen any et and mph benefits on retarding the timing back once in high gear or even at a certain higher rpm range ,, i am going to install a micro switch on my shifter and tie it into the 6al plus that can retard as much as 10*
gmonde
Old 07-09-2020, 08:21 PM   #2
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Default Re: retarding timing in high gear on a stocker
gmonde
On my 71' 402 low comp.stocker,I take out 4* after it's in high gear.Seems to be worth a couple of ticks and almost a mph...gsa612
Old 07-10-2020, 12:19 AM   #3
Adger Smith
Liked 880 Times in 311 Posts
back in the early 70's I took out 3-7 depending on the air in 3rd or 4th gear of my Z-28. Used an off set dual point distributor and switches on the shifter. Helped a few numbers and MPH, but most of all it let me run real high timing in low and second gear where it needed it.
Ed Wright remember those days??
Adger Smith (Former SS)
Old 07-10-2020, 12:42 AM   #4
Liked 5,137 Times in 1,960 Posts
We ran the dual point deal in 71, 283 / 245 and 250..Hard to nail down the ET improvement , but the MPH was there to see.
I would look at more than flipping a switch in high gear, in this day and age ;-)
Old 07-10-2020, 06:32 PM   #5
Ed Wright
Ed Wright's Avatar
Yes Sir!! Had a toggle switch on a bracket next to my shifter, high gear tripped that switch, turning the second set of points in my dual point distributor on, to retard the timing. I used 4 degrees.
Now, with my FAST XFI & crank trigger, I do it in my ECM. No switches to retard it. Now triggered by the RPM drop at the shifts. I found what high gear timing ran the most MPH, I add 4 in low gear, pull 2 of that in second, pull last 2 on the 2-3 shift.
I can shut that function off with a toggle switch on the dash. I leave it shut off in “bracket mode”. Only on if I need to qualify higher, or for a heads-up. Now, since I’m so old, I have try to remember if it should be on, or off. LOL
Ed Wright 4156 SS/JA
Old 07-11-2020, 07:49 AM   #6
richie 2
Liked 205 Times in 93 Posts
would this syatem wor
k in a superstock car?
Old 07-11-2020, 08:43 AM   #7
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Running higher timing helps the car launch harder but might be harmful down track...
Many years ago a friend I knew had a very famous and winning BB Chevy II SS'er and it came with a little instruction sheet for the timing..
It was a 396 with closed chamber heads and they liked high timing..
The sheet spec'd 54 degrees and was retarded with each gear change. It was a Turbo 400.....
I used to use drastically lower timing when track conditions were not good to try and hook better....it did make a difference....so it would work the other way too.
Has to be tried to see if it works....the ET slip tells the story..
Rich Biebel
S/C 1479
Stock 147R
Old 07-11-2020, 09:15 AM   #8
Ralph A Powell
Liked 226 Times in 137 Posts
Used in our comp car til we’re got the Acell BEI!
Old 07-11-2020, 10:46 PM   #9
Ed Wright
Ed Wright's Avatar
I would expect at least as much gain with an SS car. Bigger cams (like for an SS engine) likes (in my experience at least) like more timing in low gear. At least an automatic car.
Works for me. Five hundredths for my car.
And, the gains, for my car, came from adding timing in low gear, not just retarding in high gear.
Old 07-11-2020, 11:14 PM   #10
MR DERBY CITY
Liked 8,127 Times in 1,534 Posts
This is old news here,...can anyone say MSD grid ???? and you don’t need a sensor on the driveshaft to make this work....
